Question about HP Officejet 4355 All-In-One InkJet Printer
How to change ink cartridge hp officejet 4355 all-in-one
    President:
  • 2,049 Answers
Download the User Manual by falling this link.
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
Go to page 75 and follow the instructions to replace the ink cartridges.
Posted on Nov 16, 2009
Hi i have a hp officejet 4355 all in one printer at my place. i m having problem fixing with the cartridge as it is showing error. pls guide
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
  • 1
    Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
  • 2
    Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
  • 3
    Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
  • 4
    Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
  • 5
    Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
  • Feb 01, 2011 | HP Officejet 4355 All-In-One InkJet...
    Printer Cannot fax n call
    When this error appears in your printer check if ink are smeared on the holder where the contact panel is with the cartridge. To fix this issue use the Kleenex(perfume ) added with few drops of water to dampen it and clean off those contact on the holder. You should let the unit sit 24 hours for best results. Before printing anything run aligned thecartridgesa couple times then run clean cartridges a couple of times. Print the test page to look for the condition.
    Thank you !!
    Jul 15, 2010 | HP Officejet 4355 All-In-One InkJet...
    What is the cartridge number of HP 4335 all in One Printer
    the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
    Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
    How to check ink level for hp 4355? any suggestions? i would like to change the cartridge but.. i afraid i waste my inks... THANKS
    Most HP's have a print utility software that can show the approximate ink level. It comes in the CD with the printer. Use this to view the level.
    Sep 03, 2009 | HP Officejet 4355 All-In-One InkJet...
    INK CARTRIDGE EMPTY MESSAGE PROBLEM
    When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
    Clean the contact points on the cartridges with a dry, lint-free cloth.
    1. Open the top cover of the printer.
    2. Remove the print cartridges.
    3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
    Use a dry, lint-free cloth to remove moisture from the contacts.
    5. Insert the cartridges back into the printer.
    6. Close the top cover.
    7. Try printing again.
    If you still cant communicate try with new cartridge .
    Hope this help. Please Rate My Response! Thanks!
    PREM
    May 26, 2009 | HP Officejet 4355 All-In-One InkJet...
    ERROR OF LOW ON INK TRICARTRIDGE
    My name is Army Mason, and I am here to help. Yes this is somewhat common issue with all-in-one machines. Have you tried cleaning the metallic connectors where the cartridge goes? This is normally the issue, also are these brand new ink cartridges or did you get them refilled? Refilled cartridges can also cause issues. Try cleaning the terminals, that should resolve the issue.
    Have a wonderful week,
    ArmyMason
    Feb 24, 2009 | HP Officejet 4355 All-In-One InkJet...
    HP Officejet 4355 All in One Cartridge Error
    your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
    Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
    HP Officejet 4355 All-In-One InkJet Printer Logo
    363 people viewed this question
    Seeker5211
    Seeker5211
