Question about Brookstone Cycling
I need specs for a bicycle part. Th part is a rear wheel hub on a Kent Avigo Ridgeline 26 inch mens cruiser
  • 484 Answers
Go to parktool.com/repair and click on the hub of the bike. You will be given a series of topics to choose from and you can probably get what you are looking for by slecting hub service.
Posted on Nov 19, 2009
Can't find instructions on how to put the rear derailleur system back on after changing tire.
Firstly, why take off the gear mech to change tyre ? All you do is free the rear wheel, then slide it forward and unhook the chain.
Anyway, we'll need to know the make of the gear mech before we can advise on its replacement - a photo would be good, too.
Apr 17, 2016 | Avigo 1011584 Avigo 18 inch Scramble...
What is the o d on rear hub
Need better wording/explanation of the question - why do you need the info? The hub is merely the center part of the wheel - to which the spokes are attached, as well as the cog(s) that drive the bike from the chain. The outside diameter of the hub is not very important.
Feb 07, 2016 | Huffy 26 in. Cranbrook Cruiser Bike
How to change rear tire ?
Remove rear wheel with either a 15 mm or a 17 mm wrench. Take the tire off the wheel. If you are replacing a tire, reverse procedure. If you have a flat, replace inner tube, then reverse procedure
Aug 14, 2014 | Huffy Cranbrook 26" Mens Cruiser Bike
Rear axle replace
screw 1 of the cone pieces(that fit bearings)tapered section towards centre of axle(about 3/4 inch), then slip 1 bearing case on axle from other end with bearing side facing centre. Then insert axle into hub and put bearing on other end(bearings facing middle)then cone.
**NOTE** Put small amount of bearing grease inside hub for bearings. Doesn't have to be bicycle grease- I use auto grease as you get 10times as much for same price.
Then adjust cones by hand untill there isn't any slack and axle centered.Then screw on thin nut(both ends), it acts as lock nut for cones.To tighten correctly you need a skinny spanner to hold cone while you tighten the skinny nut. Spanners from bike shop only cost about $2. Can adjust without a narrow head spanner by leaving a bit of slack when doing up cones and hopefully lock effect between cone/nut grabs before cones are over tight(a bit of messing around without a narrow spanner).
There shouldn't be any slack between axle/cones and wheel, wheel should spin freely.
Put wheel on bike then a washer(if you have any)outside frame, then larger wheel nuts.
Hopefully all your pieces have been used. HAPPY RIDING
Jan 13, 2012 | Schwinn 26" Mens Cruiser Bicycle
Which freewheel/cassette is needed for men's schwinn coronado?
The rear wheel would determine that. I'd take it in to a real Bike Shop and have them determine the answer. Freewheels and cassettes are mutually EXclusive.
Apr 28, 2010 | Pacific International Schwinn Coronado...
Mens Titan Pathfinder Mountain Bike
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Feb 14, 2009 | TitanNet Bike USA Titan Pathfinder Ladies...
Strip the rear brake assembly
Go to parktool.com. Bicycle specific tools are required for this repair.
Dec 18, 2008 | Falcon Micargi GT 26" Beach Cruiser
Cycling Logo
94 people viewed this question
Top Brookstone Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Brookstone Cycling Expert? Answer questions, earn points and help others
