Question about Kenmore 22422 Top Load Washer
Kenmore Elite Washing Machine
Agitator appers to be striped out.... Cannot figure out how to remove agitator to see if needs replaced..
  • birchfarm Feb 03, 2008
    I have the same problem but I don't see a bolt under the cover of the agitator (I have removed the cover and the seal and I see a plastic piece centered on what appears similar to the head of a nail.)
    My agitator acts like it is partially stripped. With a heavy load the agitator makes a sound like plastic gears are rubbing and won't turn.  When I run a light load, the agitator catches and moves - most of the time, but seems to slip once in a while.  I can cause the same thing when turning it by hand.  Anyway, it sounds like the mechanism needs replacing and I just haven't been able to figure out how to remove it.
    Bill
  • Anonymous Mar 26, 2014
    agitator does not work anymore how do I repair it? Kenmore elite he 796.2927
On some you won’t see a bolt but if you look at it the white plastic that looks to have a stud in the middle is square and that is the nut you can use a 1/2" extension and ratchet to unscrew it then remove then agitator
Posted on Mar 04, 2008
  • 126 Answers
Remove cover on agitator. should be a bolt in the center.this is not common.check the gears in the agitator first.remember this agitator only goes one way.
Posted on Jan 12, 2008
How do I remove clothes from under agitator?
Believe it or not the agitator will come off. Look under the fabric softener cup. There should be a fastener (nut or bolt) to loosten. Give the cup a good cleaning while you have it off.
Once the nut is removed you can work the agitator off.
Jul 27, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
How remove agitator cup to replace dogears on a kenmore elite washing machine
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Feb 12, 2011 | Kenmore Washing Machines
How do i remove the agitator to remove a tangled drawstring
To remove the agitator you need to unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator if you want and replace the agitator cap.
Note: Damage to the snubbed, a pad like device sometimes located under the agitator cap, can cause the machine to vibrate excessively. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Kenmore Elite 45986 Front Load Washer
Agitator not working properly
remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Jan 17, 2009 | Kenmore Elite HE4 Electric Dryer
remove cap,,or fabric softner dispencer..pull straight up..look down in the agitator you will see a plastic cover,,pull it straight up...now your looking at the agitator dog cam assmbly..thats a 1/2 in nut there,,remove it you will need a nut driver or wrectet...now just pull the hold agitator up...be careful not to lose the agatitor dogs..onthejob
Jan 17, 2009 | Washing Machines
Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Washing machine agitator upper half not working I have a Kenmore Elite
Pull the fabric softener cap off, next pull the top cap off the agitator. Then remove the 7/16 bolt in the center of the agitator. Then you can remove the top part of the agitator.
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
1,410 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
