Question about HP PhotoSmart C4280 Laser Printer
I am getting a message cartridge jammed.What do I do to fix this?
  • 74 Answers
Remove cartridge and refix
Posted on Nov 16, 2009
I'm getting a "cartridge jammed" error message.
WELL that happened to me, and i just lifted the top and pressed the button (DONT PRESS HARD) and it worked. it's working since.
Feb 09, 2011 | Canon MultiPASS F50 All-In-One InkJet...
Tip
My 2710 All In One keeps giving an error message that the printer cartridges are...
Is your cartridge clogged,,,
Then in the maintenance settings in PRINTERS AND FAXES,, do a deep ink cleaning,,
If that fails then blot the cartridge on a piece of tissue damped with alcohol.. or let the cartridge sit in some rubbing alcohol for a cpl or minutes and then blot it..
As a last resort if the above fails,,, WARNING NOT A CONVENTIONAL METHOD
try boiling the cartridge for a few minutes,, MAKE SURE THE WATER IS BOILING BEFORE U PUT THE CARTRIDGE in.. so to to remove most of the air from the water to prevent corrosion
on Dec 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My printer is giving me 2 error messages. One is
For the cartridge jam, that means that either the ink is not properly installed or there is one tiny piece of something blocking the sensors. Same is true with the carriage jam.Please try to look for small bits of paper and remove it.
Is the ink newly installed?
Aug 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Cartridge Jam
hi
i assume you have got the correct cartridge for this model of printer.
i also assume that you have correctly synchronized the cartridge heat to its coupling structure in the printer.
if you have fixed it correctly and it still sticks out, the cartridge could be defective, in which case try and replace the cartridge from the vendor.
cheers
Jul 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jam message on HP C4599 when there is no jam
I had the same problem. I called HP and went through the steps they had asked me to go through to fix it. It took about an hour. Nothing worked. They offered me a replacement. I said no, and they offered me a $150 gift card for Staples.
Apr 10, 2009 | HP Photosmart C4580 All-in-One InkJet...
Can not get by carriage jam message
I had an old HP printer and it would say the door was open or the cartridge jam. It turned out the cartridge was too far to the end of its belt cycle. It is weird, but I put a finger space width between the cartridge and the wall of the printer and then it read it correctly. Go figure. It would get off cycle whenever I replaced the ink cartridge.
Jun 04, 2008 | HP Photosmart 2610 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Check drum cartridge
You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
May 13, 2008 | OKIFAX 5650 Plain Paper LED Fax
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP PhotoSmart C4280 Laser Printer Logo
Seeker5211
Seeker5211
