Question about Sylvania SRT2232S 32" TV
The infrared sensor inside TV is not working
How do I find part #, a manual, order it, replace it, or have someone else do it? Good TV, but I'm at a loss. Thank you for any guidance.
  • cwcquality Feb 02, 2008
    The infrared sensor inside TV is not working. Local repair shop says the System control IC is bad. Labor cost is $125.
    Mod # SRT 2232S. SN V32264851 Mfg 2002
    Is this plug in or hard wired? what is cost of new part?
    Charles C
  • Anonymous Dec 01, 2008
    Have a Sylv SST 4324 which suddenly stopped responding to Remote.
    Purchased new remote; same failure to respond. Told most likely in-set iR sensor is broken. Now pricing sensors and preparing to open set and look around; maybe a connection problem - not likely though.
I have the same trouble with my 32" Panasonic. Remote is gone on TV.
Going to TRY to use a DTV converter box on it IF I can get channel 3 to work!
GoodLuck to you..AND ME!
Posted on Nov 24, 2008
    New Friend:
Hello!
Posted on Sep 07, 2010
6ya staff
SOURCE:
I have a e422vle Vizio TV. The power board went bad, I ordered a new one and the Tv now is working but the remote doesn't work. Is the remote sensor on the power board?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV.
http://electro-medical.blogspot.com/
Jan 05, 2017 | Vizio E422VLE 42 in. LCD HDTV
I have a moser bear lcd tv and remote is barely working
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Feb 16, 2015 | Televison & Video
Remote and manual buttons don't work
If the panel lock is set to ON, the panel buttons won't work. If the remote control or the infrared sensor inside the TV is faulty; the remote control won't respond. Contact any service technician. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 25, 2014 | Hisense 50 Class 1080p LED Smart HDTV -...
My remote control for Haier tv stopped working, despite good batteries
Nov 19, 2014 | Haier HL32R 32 in. LCD TV
Sony bravia remote not working, and tech says not remote need to replace the sensor in tv. Can a noon geek do that.
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
If the remote control is OK, the tech might be right. The infrared sensor inside the TV should be replaced.
Sep 07, 2014 | Televison & Video
Infrared sensor on TV
Get the part number from the service manual and order one from a TV repairs/parts supplier.
Jan 23, 2018 | LG 55 55LW5600 3D LCD TV
The remote control does not workand the tv works manualy but the settings are not in order ie channels have not been set correctly,but they cannot be re set manualy
To reset and arrange channels in the order, you must have its remote control. Check whether the remote control emits infrared emission. Check it with fresh batteries. Clean the battery contacts inside it batter compartment. If these contacts have any rust or dust accumulated, there will be no proper battery connection to remote's internal circuits, and won't work well. If all are found OK, check and replace the infrared sensor inside your TV. If you wish to get more details about how to check and replace a remote control, check this link.
Feb 06, 2013 | Samsung Televison & Video
LG 52LG50 TV remote stopped working
If the standby light on the TV blinks, as any remote control handset is pressed, means, the circuit between infrared sensor inside the TV and main system control section has the fault. If infrared sensor inside your TV were faulty, this will not happen. Here infrared sensor inside the TV and remote control, are working properly.
the fault is with the main system control circuit itself. To make this more confirm, just replace the infrared sensor inside your TV. It is an easy to get component, and won't cost more too. It can be bought from most of the electronic spare part selling shops at your town. There are so many types of infrared sensors are there in the market. You have to make sure, which type is used in your TV. This part can be located just behind the infrared sensor window at the front panel of the TV. In fact, you have to open the TV to access it, as it will be directly soldered to the front panel control circuit board. For your reference, I hereby includes the images of some types of it. Just see, it is a three solder terminal component, easy to get, and easy to fit. If the fault still occur even after replacing this component, surely the main system control IC and its memory IC section circuit should be troubleshooted. This is really a skilled work.
8_10_2012_9_36_09_am.jpg8_10_2012_9_36_20_am.jpg8_10_2012_9_36_37_am.jpg8_10_2012_9_37_02_am.jpg
Aug 09, 2012 | LG Televison & Video
I have a sony Bravia KLV-S40A10E 4 years old.Remote controle device is no ore working. Batteries have been changed without solving the problem .. Other Remote device ( DVD-Sony ) is also not working...
Hello
You just check your remote control handset for its infrared emission. There is an infrared light emitting diode [LED], in front of your remote control handset from which infrared light rays are send to your TVs infrared sensor, fitted inside it, behind the infrared window on its front panel. Infrared rays are invisible to human eye. We can check if it is there by using a cellphone with camera option.
Put the cellphone in camera mode, and place your remote control's LED side towards its lens, for about a feet away or so, and when you push its each button, you can see an image in the phones' screen. If it is there, and still your TV don't work with remote control, TVs infrared sensor inside is faulty, and needs replacement.
If there is no infrared image from your remote control, you have to buy one new remote control. OK.
Dec 18, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My will not work with the remote any longer. I replaced that. When I manually turn power on, it takes 3 or 4 times before coming on. Then, it will turn off after about 30 seconds. ANy ideas?
There is an infrared sensor inside the tv to receive infrared signals transmitted by the infrared signal generating light emittin diode fixed on your remote control. Either the sensor inside the tv or light emitting diode in the remote controller faulty, remote function will not work. For manual operation troubles, check the wall power socket of plug of the tv is faulty, loose contact etc.
Oct 13, 2010 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sylvania SRT2232S 32" TV Logo
2,504 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
