Question about Canon PIXMA iP4200 InkJet Photo Printer
Error 5100 Just replaced the bigger black cartridge and it went back into the side of lthe lprinter and then started a screeching noise and a window came up to say it was error 5100.Turned printer off and on again but cannot go further
    President:
  • 2,049 Answers
You've got a carriage control error.
Try taking the cartridges out completely, look for ANY debris, no matter how small, and clean it out. Reset the cartridges back into place carefully and try again.
Posted on Nov 16, 2009
Screeching noise when starting
It sounds like the solenoid or starter may need to be replaced or both, which are usually sold together.
Oct 24, 2013 | 1A Auto Parts 1999 Oldsmobile Delta...
Wont accept a new toner cartridge makes a very
you have to cleaan all the gears. on the side and use a bit of oil.
this is a commen problem form sf 5100
May 17, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Error on screen 5100 color light &
I just went through this. My problem was that I had something obstructing my print cartridge. I took the back off with 3 screws, then the side panel (on the cartridge side). this was real easy, take the trim off and there is one screw, then find the little arrows that show where the tabs are that slide into the side of the printer itself. I used a flat head screw driver to unsnap them. Once open, I tipped my printer side ways and saw the object in there. Put it back together and now it works.
But the problem you are having could just be as simple as a loose cartridge. Take the cartridges out and put them back in making sure they snap in.
Good Luck!!
Regards,
Ron
Mar 22, 2011 | Canon PIXMA MP470 All-in-One Printer
Error code 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error 5100
Hi
Thanks for using FixYa. Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip(encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Canon PIXMA MP620 All-In-One InkJet...
My HP Laserjet 1200 is screeching constantly
Probably the laser-mirror motor. It will screech until the load gives a error and the printer shows error/ is dead.
However, the motor can be lubed. Remove sides, remove screws found, remove top cover. Remove and open the black box containing laser. Remove motor board and lube the motor, dont get the mirror dirty. Asseble. Total time 15min...
Jun 16, 2009 | HP LaserJet 1200 Printer
Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Apr 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Service error 5100 on canon pixma mp130
When this happened to me, I beat my head against the wall until I finally figured out that the waste ink absorber on the right side (spongy looking thing), was overflowing, and clogging the nozzles. I took a piece of paper towel and absorbed some of the ink. Make sure to wipe the colored ink absorber as well.
Neal Moilanen
AAA Virtual Assistants
http://www.aaava.net
Jan 24, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Nov 12, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Error message: Service error 5100 on my new Canon MP160 Printer
Error Code.........Description
5000 ...................Home position error
5100 ...................Carriage control error
5200 ...................Head temperature sensor error
5400 ...................Printer temperature sensor error
5600 ...................No cartridge error
5C00 ...................Purging operation error
5200 ...................Scanner cartridge error
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
good luck (^_^)
Aug 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP4200 InkJet Photo Printer Logo
171 people viewed this question
old marine
old marine
