Question about HP OfficeJet 6110 All-In-One InkJet Printer
I put my cartridges in backwards the ink spots facing outward, I tryed everything, a butter knife , pushing, pulling, nothing is working to get them out, I dont want to force them, Im afraid ill break it??
  • HP Expert
  • 2,973 Answers
You are right, as it really may break. It needs to be pulled out with a very slight downward pressure.
Posted on Nov 16, 2009
How to open Hanns G 28" monitor.
3 screws across top and 2 in lower images?q=tbn:and9gcszcucatuwbsigg82atflilcifasvtk3ai5_wt5czzf6sn7tgq_0q3 screws across to and 2 in lower corners
if this helps please take time to rate
Feb 01, 2013 | Hanns.G Corporation HW Computers &...
How to load a MP130 cartridge?
  • 1 Turn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
  • 2 Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
  • 3 Pull out the used ink cartridge by pulling straight up from the print head,
  • 4, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
  • 5 Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
  • Nov 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
    shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
    Apr 25, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    How do you remove the door panel on a 1994 nissa pickup? the window is off the track. i do not see a way to remove the handle that opens the door.
    If man did it, man can undid it. The panel os held on with push on typ screws made of nylon. find a spot you can't lift with a butter knife and get on the other side of it with another butter knife and lift it out or pull the door panel off withou damageging the panel.Do not bend the panel anymore than it takes to pop it loose. When you get one out far enough you with see what it is.
    Nov 07, 2009 | 1994 Nissan Pickup
    How do you remove the face plate the is on the
    Remove the top hinge cover , covering the top freezer door hinge , and unplug the visible receptical . This removes power to the dispensor and dorr . Using a butter knife between the grill and the dispensor bottom cover , push down and inward , prying the cover outward . Do this on both sides , about 1 " from each side . This pops the plastic clips off . Raise the cover to release from the upper plastic retainers . Disconnect the plug from the cover and its removed . Do this carefully , because your working with plastic . To reinstall , reconnect the plug to the dispensor cover , slide the top in place and pop the lower tabs back into place . Reinstall the top hinge plug and cover .
    Aug 29, 2009 | Whirlpool Refrigerators
    Game is stuck inside ds
    the game is probably in backwards. if you can still see the top of the cartridge then try and use a butter knife to push it out. Hold the DS so that the knife and cartridge will slide away from you and press the knife down on the small lip at the top of the cartridge and forward.
    Jun 01, 2009 | Nintendo DS Console
    CANNOT CHANGE INK CARTRIDGE,CARTRID GE IS ON FAR LEFT SIDE OF PRINTER SO THAT i DO NOT HAVE ACCESS TO IT. iT IS A MODEL 8300.
    turn off machine, open and get a knife (or something flat) and put on top of the cartridge and push down, then try pulling to the middle.
    The problem is that somehow the latch that holds the cartridges is open.
    Aug 20, 2008 | Lexmark Office Equipment & Supplies
    C60 says full cartridge is dry
    You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
    Change the cartridge when prompted.
    Of course, having messed about with the jet, it may not work now !
    Jun 05, 2008 | Epson Stylus C60 InkJet Printer
    Help
    Reach into the papar slot directly above the display screen, (where you would place the paper to be faxed, pull outward, this will hinge downward
    There is a small finger hole just below the fax/paper (face down) symbol. Pull outward, this will hinge upward.
    The cartridges will move to the center of travel. If you get this far the instruction are on the underside of this flap. The cartridges snap out by pulling toward the front.
    COLOR = #20
    BLACK = #70
    Jan 02, 2008 | Lexmark X125 All-In-One InkJet Printer
    TO PUT IN INK AND USE FAX
    The ink snaps pretty hard into this unit. Make sure take the little clear tape off of the bottom of your ink cartridge. Open the fax machine, if there is already an ink cartridge there, you have to pop it out. Pull it from the top colored part of the cartridge. Take your new cartridge with the side with the number on it facing you, and just push it in. It's easy, it just might seem like it's not going in right because it is kind of hard, you have to push it a bit to get it to snap in.
    Sep 05, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    185 people viewed this question
    Seeker5211
    Seeker5211
