Question about Visual Land V-Touch Digital Media Player
My V touch only comes on if i plug in a USB or charger wire. video's and pics look blue and off color. If i turn on the device with the on and of button i only get a blank screen. I tried resetting the device and manage to get the color back but as soon as I access videos it returns to the blue like look. Also my V touch says its charging when it's not everytime I turn it off or while I'm using it. The main screen doesn't appear as bright and when I plug a USB or charger wire into it the colors look like they have too much color to the icons and background screen. Also the windows just jump to what you choose instead of transend and like a slide show. Usually the window text has a blue bar when it's highlighting text mine is orange.
  • 68 Answers
OK that is a malfunction in manufacturing that happened to my first one send it back with a note explaining what doesnt work they will send you a new one back and if your nice to them sometimes a complmentary item from visual land
Posted on Nov 25, 2009
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
Just installed a 1200 all in one HP printer and it goes through the motions of printing but nothing is on the paper, i have deleted, reinstalled, check every setting possible, done everything that the...
Many a times the cartridges get empty.There is ink in the cartridges,this ink gets over or many a times dried up.Remove the cartridges and see.There will be a steel color nozzle at the base of cartridge,from where the ink comes out.Touch the tissue paper to that base and see,if there is ink coming out.Actually the ink should come out.There will be two cartridges in the printer.One black and one tri-color.On black cartridge when you touch the tissue paper you will get black ink on tissue.On tri-color cartridge when you touch tissue on its base you will get three colors,that are yellow--- blue and pink.( In printer language its called cyan--- yellow---magenta color).If there is ink in the cartridge then it should print,If you have replace the cartridge,then on its base there is a blue color tape.That tape has to be removed from its base.If the tape is not removed the cartridge will not print.-------- One more thing.Before doing any thing.Just do a self test and see if the cartridges are working. The procedure of self test is as follows:--- " 1) Turn the printer on.2) The power on green light should be steady green,not blinking green. 3) When its steady green at that time.Press the cancel and color button both together. 4) By doing this the green light will flash,and printer will take the paper. 5) On that paper the self test will get printed.But if the printer takes the paper and it comes out empty /blank then its cartridge fault.But if the self test is getting printed,then yes its confirmed that there is communication fault between printer and computer.In this case,replace the usb wire.Try new brand usb wire and see if that is helping.One more thing.When you install the printer driver.At that time never keep the usb wire connected between printer and computer.Only keep one side of usb connected to computer tower.In between the installation procedure.The message will come up on your computer screen" this message reads,connect the usb wire to printer.At that time connect the usb wire".As you connect the usb wire the message will come up on your computer screen.The printer is detected.If this message comes up then only your printer will work.If this message does not comes then,there is any of the three things faulty,that is usb wire,the usb port on printer side or usb port on computer side.If usb wire is faulty you can replace this wire with new and check.Its not a costly wire.But if any of the ports are faulty,then this ports are internally soldered on the main board.This ports needs to be re-soldered.This can be done by any printer/computer repair tech.Its hardly a 10 minute job to re-solder loose usb port. ------------- Try this troubleshooting procedure.This will help. Thanks.Helpmech.
Jan 27, 2011 | HP PSC 1210v All-In-One InkJet Printer
Hi I have a 691 and want to outlet on all the time and the switch to control a light. Your diagram show black wires on one side and the white wires on the other side. Shouldn't a black wire be on one of...
If your switch is wired internally so the switch automatically controls the plug, then there is not a way to re-wire the insides of that device.
Look at the screws on your device.
If switch automatically controls the plug, there are probably gold-colored screws on one side of device and silver-colored screws on other side of device.
The blacks connect to gold, the whites to silver
If this is how your device looks, then the switch cannot control a light, so buy a device that looks like the one described next:
If the plug and switch can be wired separately, then the screws are different colors
1) On one side are dark-colored screws. The Hot wire from breaker box always connects to dark-colored screw.
2) On the other side of the device are 1 gold-colored screw and 1 silver-colored screw
- The white wire connects to silver screw and this will complete the circuit to the plug
- The wire going to your Load (light, fan motor) connects to gold-colored screw, and this will let the switch control power to the Load
You can buy a simple continuity tester and check your wiring devices before purchase:
Continuity tester is used when power is turned off.
It has a battery
When you youch alligator clip to the tester point on end of tester, a light comes on.
When light comes on, that tells you the circuit is complete
For testing switches and plugs, you touch the pointer on one screw terminal, you touch the clip to another screw terminal ... then flip the switch on the electrical device to see which screw terminals cause the tester light to come on
If light comes on, then the circuit has 'continuity'
Continuity tester can be used on all sorts of small electrical devices, including troubleshooting electric water heater >>> and that's a fun project for next week.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 18, 2010 | Pass & Seymour #691 15A Brown...
The wires on the cig lighter side of my iTrip auto 2008 pulled out and I want to solder them back in but I need to see which color wire goes where...? I can do the soldering fine but I want to make sure I...
my itrip is a little different but im pretty sure they layout would be the same. but on mine (2010).on the botton side..
A= Blue wire
S= n/a
LR=n/a
LG=Purple wire
V=Green wire
Other side (Left Side)
R=Orange
S=Green
L=Red
Sep 07, 2010 | Griffin Technology iTrip Auto Universal...
I do not know how to connect to my tv to get a picture
hi here is what you can do try plug red green and blue plugs into phillips it should be color coded and then plug same colors into back of tv colors should match then press tv input until you get pic make sure dvd players is on and playing or you can use s video plug only good for pic you wont get sound you would need to plug in rca for audio and turn tv input to s video or if you have hdmi input all you need is one cord for video and sound and you can get full hd on it if player and tv is both capable so plug it in to hdmi 1 or 2 and turn tv input to hdmil 1 or 2 where ever you plug it in also make sure dvd players is on and playing
Aug 27, 2010 | Philips MCD-735 System
How do i transfer the pictures and videos from my Experia X10 to my laptop computer. i plug in the usb cable and double click on the portable device icon in My Computer and it asks me to insert a disk....
I Junebunny75
To Transfer pics/videos from X10 to PC/laptop...
first of all plug in the cable that comes with the X10. (It is the same one that plugs into the top of the charger)
into a USB port on your PC/Laptop.
Then Open the cover on the top of the X10 handset. (The one that hides the charger port)
Now plug the cable into the charger port.
Your handset should be switched on.
In the top left hand corner of the X10 display should now have a little USB symbol on it??.
If it does just ttp the symbol and drag your finger downwards.
This now shows what you would like to do with the USB.
It says something like. "Select to copy files to/from your computer" Just tap this prompt then a pop-up appears asking to "Mount" or "Don't Mount"
Tap "Mount"
This will now prompt your PC/Laptop to load the correct drivers.
If you are using a Windows PC/Laptop it should find drivers fairly easily as it is just a "Mass Storage" device.
When/If it has done this it will say "Device Connected" or similar.
You can now go into "Start"
"Computer"
And in there you should find a new drive.
This will be your phones memory
DCIM is the folder with your photos in it.
I hope this helps?
Aug 15, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Cant get webcam on to take pics
Hi there follow the instruction below.
1**. Double click my computer then double click USB Video Device. You can see your self then. After there is an blue colored text option " Take a new picture" click there & take snapes. Thanks.
Mar 19, 2010 | Advent Netbook
Music Video
i can`t get my i pod to turn on.how do i do that?all i get is a picture of a disk with a music note on top with a usb cable pic pointing toward the disk and music note. thanks
Feb 12, 2008 | Apple iPod touch
MDA (i really need this phone to work, my fav. phone)
The freezer thing was a stupid idea. Maybe your charger is not an original charger? or if it is the charger port could be loose.
Sep 13, 2007 | T-Mobile MDA
Visual Land V-Touch  Digital Media Player Logo
145 people viewed this question
Top Visual Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Ed Mac
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
