Question about Yamaha Full-Size Keyboard
Buying a PA-301 power supply for the PSR-S710 in the US. The PA-301 has an input from 100v to 240v does that work automaticly i.e. if I change the US power plug to a NZ plug which has a power supply of 220/240v it should work ok. Ron Currie
2 Suggested Answers
  • 1705 Answers
SOURCE: i recently purchased a yamaha PSR-E223 YPT-220
Does the user guide tell you should have got this adaptor along with the keyboard? Often there's a "what's in the box" page. They normally do include one.
I would suggest firstly going to Argos and getting a replacement or ask them to supply one. You'll need your receipt.
If not then any universal AC mains adaptor which can supply 12v DC and the correct plug (2.5mm) will do the job.
You should be able to get them from Maplins, Ebay or here's a web site:-
http://www.uk.best-price.com/search/landing/query/Pa+3c+Adapter/s/google/koid/3442910623/
Posted on Jan 02, 2011
Testimonial: "i went back to argos with a reciept and although the box states adaptor supplied none of the boxes instore had adaptors in them.i will try e-bay.thank"
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Casiotone 301
HI, Your unit is very old and it can be repaired. Look for someone who does vintage synthesizer repair. John, Syntronics.
Oct 17, 2013 | Music
Psr 60 no sound
Are you using the original PA-4 power adapter that goes with this unit? Using the wrong one would cause it to not work properly. Weak batteries would do the same. A generic power adapter would also, if working would cause static noises in the sound. The PA-4 is an odd unit, it is 10volt DC at 1 amp output. IF the one you are using is less than 1 amp, meaning if it says 400mA or something with an "m" in front of the A, UNLESS it is at least 1000, then it isn't strong enough to work correctly, EVEN if it powers up. If you have the wrong one, you can find it here:
https://www.google.com/search?q=Yamaha+PA-4+power+adapter&hl=en&source=univ&tbm=shop&tbo=u&sa=X&ei=kPFbUeb1LoPk9ATzwIDwBw&ved=0CD8Qsxg&biw=1440&bih=756
I hope this helps you.
Mar 31, 2013 | Music
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
What's your problem?how can i connect my mic in YAMAHA PSR s710
I believe you must have a USB audio mic. If you do, plug it into the USB port in the back of the unit;
Aug 07, 2012 | Yamaha Music
I have a Eupoport EPA 900 system. Recently I started getting a consistent, low pitch and fairly loud hum out of both speakers. The hum adjusts with the volume, and I have tested it with various working...
Is the hum there with NO input cables connected? If not, you have bad cabling. Make sure you use only XLR to XLR mic cables and not the junky ones with a 1/4 inch plug that are for Karaoke machines. These devices usually use switching power supplies and do not have the power supply originating hum of older equipment. If the volume control adjusts the hum, then the hum originates previous to the control which is either in the preamps or the external inputs.
Aug 25, 2011 | Behringer Europort EPA900 Ultra compact...
I recently purchased a yamaha PSR-E223 YPT-220 keyboard from Argos.when we got it home and opened it there was no adaptor.We are unable to find the one we need.The manual states we need a PA-3C...
Jan 02, 2011 | Yamaha Full-Size Keyboard
Please teach me how to do a recording of bits with the keyboard PSR S710, it uses a USB drive, but i don't know how to use it
You need to have a basic recording program installed on your computer. If you use Apple you can use garageband. If you use Windows you can install audacity http://sourceforge.net/projects/audacity/
You will have to install the drivers of our yamaha keyboard than connect it with the usb cable to your computer and select the PSR S710 as an input in your recording program.
Mar 10, 2010 | Yamaha Music
No volume at all out of speakers PSR-E203. Plugged in to AC supply. Yamaha Portatone PSR-E203 YPT-200
Make sure you use correct power supply.
Try headphones. If they work, then the switch on the headphone jack that disconnects the speakers may not be working properly and not connecting the speakers.
Oct 13, 2009 | Yamaha Music
Yamaha Full-Size Keyboard Logo
120 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
