Question about Hotpoint Ultima WF860 Front Load Washer
Error message f7 on display of Hotpoint Ultima WT960. Any suggestions please?
  • Anonymous Feb 18, 2008
    my hotpoint wf860 keeps flashing up f07 i have to turn it of and on again then it will wash but it will not spin at end of wash so i have to turn it of then on again and then put it on a seperate spin cycle its a lot of messing around especially when you have a lot of washing to get done
  • waywards Jun 29, 2008
    my machine starts filling then beeps and stops with flashing F-07
  • 4 Answers
We have a Hotpoint Ultima WT960. It has come up with error message H20. Could this be a frozen pipe issue? Thanks in advance for your help.
Could well be so.
I would suggest you turn the supply off to the washer, remove the hose/s, and check to see if water if present.
Dec 07, 2010 | Hotpoint Ultima WF860 Front Load Washer
I need to download a user manual for a hotpoint ultima wt960 please
Go to---
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on--
HOTPOINT USER MANUALS
Ithe search box, enter your model number, and download the instructions.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint ultima wt960 with f01 error can I fit the part
Hi
f01 means motor fault. remove motor and check the brushes. if ok then fault could either be motor or pcb which is faulty.
regards
Mar 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
F10 means that the water level switch is not sensing the correct water level, this can be caused by faulty switch, a blockage in the pressure system, a blocked drain pump or filter.
It is a process of elimination I'm afraid.
Please rate my suggestions to solve your problem.Thanks.
Mar 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 lcd screen failure
Hi, I have experienced this problem on several hotpoint machines with led display's. There is really only one solution for it! If there are no wires hanging off then the answer is in the board, And you will need to replace it. It is a non servicable part and cost around £40.00+++.
Good luck.....
Dec 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960
its either a fill valve or you water taps are faulty ie; rounded off knobs easey fix please leave feedback good luck
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
514 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
