Question about RIM BlackBerry Pearl 8100
When sitting idle, my pearl lights up randomly. i
When sitting idle, my pearl lights up randomly. i think this is draining my new battery.
    Scholar:
  • 77 Answers
Try this Hold down the ALT key, and press right-hand CAP key press the DELETE key aswell together which resets the blackberry
Have you installed any new application?. Bcoz this is happens due to new application (themes).Please delete the particular application and check.
Posted on Nov 16, 2009
I have a 93 ford explorer that dies while sitting an idle (when this happens the dash lights go dim as if draining power and then it dies). Would this mean I need a new alternator?
Not Necessarily, first I would adjust the idle so that the revs are around 800, then check the tension on the belt connected to the alternator as if it is too slack then the alternator will not charge the battery hence the fading lights.
Nov 11, 2014 | Ford Explorer Cars & Trucks
Car battery goes dead within 3 days it is my new pioneer radio that drains it.
Would not think so, radios do not use that much power. My car sits idle for weeks, still with power to constant 12v. Check your battery, IF going flat that quick, probably needs replacing
Mar 18, 2013 | 1996 Jeep Grand Cherokee
Battery keeps draining when car sits for several days.
Try this to see if you can find the drain: Wait until the car has been off for a half hour, so computer is in sleep mode. Open hood and remove underhood light bulb. Take off negative cable from battery and hook up a test light between cable end and battery post. If you have a drain, bulb should be brightly lit. Start removing fuses one by one until light goes off. When a fuse is pulled that turns light off, that is the problem circuit. Check everything on that circuit to find what is staying on.
Jan 23, 2013 | 2002 Lexus RX 300
Autozone.com
Pull your fuses one by one until the power drain stops. Also relays contacts could be melted together
Dec 17, 2011 | 2001 Ford Taurus
My blackberry pearl flip 8220 freezes randomly,
Invalid sim means it's locked to a career but your simcard's career, to unlock your BlackBerry go to http://blackberrymep.com and get your unlock code along with unlocking instructions .
May 14, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry shuts off and red light keeps flashing. I take the battery out and put it back in and it still wont work. Then randomly it will turn on and work for a bit. Im so lost, please help!
The flashing red light is telling you that the battery is almost drained down to capacity and that the phone must be plugged in now. When the charge is this low you are going to have to leave the phone recharge for at least 12 hours before trying to use it again. Once the phone is turned back on, the phone will reset itself. Good luck.
Mar 01, 2010 | RIM BlackBerry Pearl 8100
Honda cbx 6 clutch rattle at idle and low rev hirendouse
Glazed alternator clutch plates? Kind of a ratcheting sound? Common when oil wasn't changed or sitting unused too long.
1. Easy fix - drain oil, remove filter. Add diesel fuel to crankcase. Turn engine over. let sit and drain. Refill with new nonsynthetic oil and replace filter. Warm up. Drain, remove filter. Refill with fresh nonsynthetic oil, and install new filter.
2. Harder, but better. Remove plates and clean or replace them.
Mar 04, 2009 | 1982 Honda CBX
Blank screen
i think there must be water or some scomponents for th same please check it out wid ur nearset tech
Jun 16, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
85 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
