Question about Canon PIXMA MP830 All-In-One InkJet Printer
Cannon pixma mp500 code error 6500 - Canon PIXMA MP830 All-In-One InkJet Printer
    President:
  • 2,049 Answers
The error code of 6500 is a PCI bus error and this is a Service Error Code. Typically this is an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Sorry fro the bad news!
Posted on Nov 16, 2009
3 Suggested Answers
Angel Bird
  • 287 Answers
SOURCE: canon pixma mp500 error 6500
Hello! Welcome to FixYa
First try this to solve error 6500:
Firstly Reset the printer and
Turn the printer off with the Power button then disconnect the data cable from the printer.Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Turn the printer on. If this works you have solved the problem If this not works then try the next step:
After confirming that the printer is powered on,open the paper output tray and Open the top cover and wait until the print head moves to the center then Open the inner cover and check that ink tanks are properly seated.Press down on each ink tank until a click is heard.Close the inner cover and top cover. Also do you have any kind of data equipment like a camera connected, if so this could be causing the problem as well.
If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Posted on Dec 14, 2011
  • 3230 Answers
SOURCE: error code 6500 flashing
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Posted on Oct 01, 2009
Error code 6500
mau tanya gan error 6500 knp yh thx
Jan 12, 2013 | Canon Pixma MP500 All-In-One InkJet...
I have a cannon pixma mp 500 printer and I and getting a error code 5010 how can I fix this issue? Thank You
unfortuantely according to canon website, if turning it off/on doesn't clear the error then it will require a "repair service". Doesn't acutally say what the problem is I'm afraid.
good luck
Don
Sep 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
I have a cannon mp560 printer and receiving a error 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. I would contact Canon Support to find the closest location to take it to or send it to. Thanks, Rick.
Jul 29, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP500 showing error 6500 on lcd display
This unfortunately is a logic board fault and it will have to be replaced. thats the only fix for it. srri
Jul 17, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error code 6500
Issue: ERROR: Error code 6500
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request
If the above does not help:
Solution: The MP500 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
Find a Service Location
Nov 11, 2010 | Canon Pixma MP500 All-In-One InkJet...
Turn on and error 6500 displays? How to fix?
The Service Manual for the MP500, which is very close to the MP450, indicates that the error code of 6500 is a PCI buss error and this is a Service Error Code. Typically this is an internal error of one of the ASCI chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
If you want to take the time to try and repair it, you can take the unit apart and search for a loose connection, or unplug and replug all connections. Other than that, you can sell it for parts.
Good luck
Aug 11, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error 6500 on a Canon MP500
choy ada yg tahu printer canon pixma mp500 error code 6500 g y? please help me
May 12, 2010 | Canon Pixma MP500 All-In-One InkJet...
What does the trouble code on a cannon printer
4. Properly seated
Thanks.................
Jul 17, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Cannon Pixma MP500 - Waste Ink Reset
I don't belive there is a reset device for the MP500 tanks. However, when you get the empty error message, just follow the instructions about pressing OK as many times as it asks for (I think it is four time). At that point, you can continue to use the cartridges. The printer will no longer keep track of the ink level. You will have to do that yourself. But, you can continue to use the printer with all colors.
Dec 09, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
6,404 people viewed this question
old marine
old marine
