Question about Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router
Internet Connection My Microsoft MN500 wireless base station does not recognize internet connection. Also doesn't allow internet connect from router to desktop. I've reset both cable modem and router several times and replaced cables. I can access the internet from cable modem when i connect directly to desktop. Suggestions?
  • 2 more comments
  • wedwards May 05, 2008
    I'm trying to add a new laptop to my existing home network which is set up on Mictosoft Broadband Utility. The new computer says that there are known compatibility issues to get a later verion. Where do I get this
  • odd creation May 19, 2008
    i just hooked up a microsft mn-500 router to my desktop and modem. about 20 ft. away in the garage is a laptop computer that has wireless. and the internet is coming in just fine. the problem is at the desktop their is no internet. why?
  • msmatt45 Aug 20, 2008
    I changed modem and now can only get local access on my router
  • Anonymous Oct 05, 2008
    no internet/excellant signal
I'm just trying to figure out why I can get an excellant signal, but can't connect to the internet, why?
Posted on Oct 05, 2008
    Problem Solver:
  • 19 Answers
You know it is not your connection nor is it your modem. Contact your isp and ask them to release and renew your ip lease. Then connect the router and retry. Should be good. Otherwise contact Microsoft
(800)936-3900,
choose 1 from the confusing menu. The line is free, open 24/7 and there is no
waiting. The best part is that they are very knowledgeable and helpful
Posted on Jan 09, 2008
6ya staff
SOURCE:
Microsoft mn500 router: the wireless part stopped working.
  • reset the wireless settings on the router page, call your router tech support to access the router configuration page
Aug 11, 2009 | Microsoft Broadband Networking MN-500...
I have cable internet but it will not recognize MN 500 base station for internet
You need to perform MAC Address Cloning. Make sure the physical connection is fine. From modem to internet port of router, from pc to port 1 of the router as well. Now open the admin page of your router and look for MAC Address Clone settings. You have to enable it and click on Clone. Save the settings and power cycle your device for 1 minute.
Jun 26, 2009 | Microsoft Broadband Networking MN-500...
Can connect to router, but not to internet
Is the main computer connected to the router or to the internet directly? If it is a cable modem for the internet, make sure you turn that off, as well as the router, and connect the cable modem to WAN on the router and put the modem on first, then the router. Connect the computers, xbox, etc to the router
Jun 06, 2009 | Microsoft Broadband Networking MN-500...
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Microsoft Wireless-G Base Station MN- 700
Just remove the router and reinstall it. it will ask you for new Base name Etc and new wirless network name with new security key codes.
Aug 20, 2008 | Microsoft Broadband Networking MN-700...
Not able to connect to internet
1. try to check the status of the connection:
make sure it is connected and the status does not say either of the ff:
a. local only
b. limited or no connectivity
c. limited access only
2. try to change the network name [ssid] and the network key [wep or wpa passphrase]
you can change this by accessing the ipaddress of the router or its user interface
3.try to reconnect to the new network name
and make sure the status says connected.
this is not a browser issue . it is with the connection set up.
Aug 05, 2008 | Microsoft Broadband Networking MN-500...
Loosing Connection between MN500 & MN520
If you are using XP, and installed the proprietary WiFi software (not the built in XP software), did you turn off the Zero Configuration Wifi SERVICE? Running both will cause issues with your connections..
Start > Run > services.msc (ok)
Dec 22, 2007 | Microsoft Broadband Networking MN-500...
Network, Internet, or Base Station Management Tool Are Unavailable
To resolve this issue, turn off Internet Connection Sharing on your network connection: 1. Click Start, click Control Panel, and then double-click Network Connections. 2. Click your network connection, and then under Network Tasks, click Change settings of this connection. 3. On the Advanced tab, clear the Allow other network users to connect through this computer's Internet connection check box. 4. Click OK. 5. Restart your computer.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router Logo
255 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
