Question about HP Pavilion dv6225us Entertainment - Turion 64 X2 TL-50 / 1.6 GHz - RAM 1 GB - HDD 120 GB - DVD RW PC Notebook
HP Pavilion dv6225us won't boot (power not the issue)
When I press the power button, the LEDs will light up, but only for a couple of seconds before the machine goes dead. After numerous attempts, the fan will kick in and the hard drive will spin, with the LEDs staying lit. This will last about 15-20 seconds, then everything will shut down, sometimes briefly coming back on again, sometimes not. If I press F10 during the 15-20 second window, the LEDs will stay lit indefinitely, but the machine will never boot.
  • 54 Answers
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Posted on Nov 16, 2009
My HP pavilion dv6700 won't power on. I have a blue light at the power cord but can't power up.
disconnect the power adapter 2) disconnect the battery too 3) Press the power and hold the switch button power by 60 seconds. Then proceed in reverse and Power again and can be fix it.Of course if the problem remain test the memory from your pressing the key f2 or f9 depending of your modell in the reboot and go to the test memory.
God bless you
Mar 22, 2013 | HP Pavilion dv6000z Notebook
My Hp Pavilion dv9831cl laptop quit working and won't power on, even with a full charge or plugged in. I press the start button, it lights for about a second then shuts off. Any suggestions? If I
Laptops use shared RAM, part of the main RAM is allocated as video RAM.
If the RAM is faulty then this could be the problem, get the RAM tested at your friendly computer repair shop.
Apr 06, 2012 | HP Pavilion dv9823cl Notebook
HP Pavillion dv4 turn on and the fan start for a second twice and then tunn off After around 5 seconds a few leds are blinking Hard Drive work fine on other laptop What can be the reason
Hello, that sounds a motherboard problem...
Try to do this first :
1- take the battery out and disconnect from power
2- press and hold the power button at least 10 seconds
then put only the power cable not the battery and try to boot...
If this dont help...your motherboard needs to be repaired or replaced.
Thanks.Please rate this answer
Jan 25, 2011 | HP Pavilion dv4-1120us Notebook
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a HP Pavilion dv6225us laptop, and cannot get the battery compartment out. The release latch does not work.
Cheek for screws if any. if not (1) Press slide and hold the battery latch toward the outside edges of the computer. (2) Slide the battery Straight back still pressing to Remove.
Dec 09, 2009 | HP Pavilion dv6225us Notebook
My hp pavilion was fine but it discharged
ok it sounds like your battery was damaged when it discharged. try removing the battery and plug in to wall socket. boot computer ,.. if it boots up completely then you will need to replace your battery
Sep 22, 2009 | HP Pavilion ze2000 Notebook
Pavilion dv6000 when power button is pressed,
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
Jun 19, 2009 | HP Pavilion dv6000t Notebook
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
Dv6225 us
1 >REMOVE BATTERY AND CHECK WITH ONLY ADOPTER
2> RESTART PRESS F2 IF DISPLAY IS COMMING THEN RESTART AGAING AND PRESS F8 PLAY IN SAFE MODE
Jun 21, 2008 | HP Pavilion dv6225us Entertainment -...
HP Pavilion dv6225us Entertainment - Turion 64 X2 TL-50 / 1.6 GHz - RAM 1 GB - HDD 120 GB - DVD RW  PC Notebook Logo
553 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
