Question about Sanyo Microwave Ovens
Replace light bulb on SANYO EM-U1000W Compact Microwave Oven
  • 456 Answers
PLESE BEFORE YOU DO ANYTHING RFER TO A GUI HOW TO DISCHARGE A HIGH VOLTAGE CAPACITOR OR SEEK THE HELP OF A MICROWAVE TECHNICIAN. As for changing the bulb, if you remove the case you will be able to locate the bulb, and merely a case or removing ad replacing with a new one. Good luck.
Posted on Nov 16, 2009
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
How do i change bulb in sanyo microwave EM-SL30N What do i do must i take the cover off what is the easy way please.
Make sure it is unplugged. Yes you must take the cover off and you will see the bulb. Gain access to it and replace it. Do not interfere with anything else.
Nov 09, 2009 | Sanyo EM-Z2100GS Microwave Oven
Microwave blowing fuses
Sanyo isn't that great of a manufacturer.. I had a microwave from them a few years back that did the same thing.. The wiring inside the microwave is shot.. if you were to open it up, you'd probably see some burnt wires from a short. If you use the microwave over a range, it may be because of grease build-up...
anyhow, its better that you invest in a new microwave, rather than fix it. It will be much more cost efficient
Jun 02, 2009 | Sanyo EM-U1000W Microwave Oven
Microwave won't shut off
the timer is more than likely broken. There are no replacement parts and the mocrowave will need to be replaced...or keep the door open when not in use, and use a watch to keep track of cook times
May 05, 2009 | Sanyo EM-U1000W Microwave Oven
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Oven not working
Just click below for more information;
http://www.repairclinic.com/0088_6_1.asp
Hope this may help;
DON'T FORGET TO RATE:
Sep 02, 2008 | Sanyo EM-A5200SW Microwave Oven
Sanyo Em-u1000w
i have the same microwave and mine does the same thing,try this push the clock button and enter the time or just push 100 and hit the clock button and then enter in your cook time and hit start.
Jan 10, 2008 | Sanyo EM-U1000W Microwave Oven
Microwave is on but the keypad doesnt respond
It may be in child lock mode. Your owner's manual will cover that. On the Sanyo EM-S5595, for example, you turn the child lock off and on by pressing and holding the STOP/CLEAR pad for 3 seconds. Yours may be the same. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, may be damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top, direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or by infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Instead apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If it looks like you need service, this is a good place to start: http://www.sanyoservice.com/
May 13, 2007 | Sanyo EM-U1000W Microwave Oven
Microwave Ovens Logo
362 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Oscar Netto
Oscar Netto
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
