Question about Whirlpool 24 in. GU2500XTPS Stainless Steel Built-in Dishwasher
Whirlpool Gold Quiet Partner III... soak/scour light won't go off
Whirlpool Gold Quiet Partner III... soak/scour button & time remaining window (two dashes) remain on when not in use. I can activate the accu-sense cycle & the sani rinse (the normal combo I use), which allows me to "turn off" the soak light. After pressing start, the cycle starts normally for a few seconds but then it just has a mind of it's own. It flips to the soak/scour mode which flashes 4hrs remaining. Then it'll flop back again & again. I hit cancel & then the drain started with 2min remaining. So I flipped the breaker & left it sit overnight. Flipped the breaker & right back to the 2min, draining mode then directly to the soak mode. Now the buttons don't seem to be reacting at all. I've repaired the matching microwave & put two compressors into Whirpool's Jenn-Air Fridge all in the last 4 months. As soon as the fridge was finally fixed, this started. the appliances are only 4 years old. Please help, I can't afford any more "service calls" right now. Thanks so much!!!
huuum
  • 750 Answers
SOURCE: whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Posted on Oct 05, 2008
  • 38 Answers
SOURCE: The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Posted on Feb 23, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a whirlpool Quiet Partner I. HELP Drain light flashing
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
Posted on Jul 11, 2009
  • 52 Answers
SOURCE: quiet partner II is stuck in cancel/drain mode...
you need a new cycle selector ...or "timer "....
Posted on Jul 25, 2009
  • 6 Answers
SOURCE: sani rinse, power scour and air dry does not work
wat does it do?
Posted on Feb 10, 2010
Quite partner iii soak and scour light blinking. Machine wont run
Open the door, press cancel, wait for about 10 seconds, reprogram after you read the owners manual. when that light blinks it's telling you that your not programing something properly.
Dec 27, 2014 | Whirlpool Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Cannot unscrew cap on rinse aid compartment in door of Whirlpool Gold Quiet Partner III
the cap doesn't come off, you just have to open the door all the way. then, when you pour the rinse aid into the dial area, it will get sucked into the dispenser. but if the door isn't open all the way it won't go anywhere and will overflow on you.
Jul 08, 2008 | Dishwashers
Whirlpool 24 in. GU2500XTPS Stainless Steel Built-in Dishwasher Logo
405 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
