Question about Epson Stylus Photo R300 InkJet Printer
Changed the ink cartridges and the printer will not work..checked all the plugs etc..printout on the LCD is for photos..a program we have not used
  • Circe Denyer
    Circe Denyer May 11, 2010
    Did you see that the ink latch is down?
  • 55 Answers
Directly is not change it will change the cartridge you go to printer service setting
Posted on Nov 16, 2009
My print outs are having lines across them
You need to have your printer go thru head cleaning cycle. Check to make sure the ink is not leaking from the cartridge. Are you using OEM ink or second hand?
Jun 20, 2014 | HiTi P720L Photo Printer
Bad printout
Hi have you installed the software that came with the printer.
Also has this problem just started or has it been like it since buying let me know ok thanks
Dec 14, 2007 | HP OfficeJet Pro K5400dn Photo Printer
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Why does the entire photo printout with a pinkage color overlay when indicating using glossy photo paper, even different photo paper. This occurs with several different programs not just Photoshop. I've...
That happens if you put photo cyan where the plain cyan ink should be, also photo magenta is too weak to be used in the magenta slot. I've also seen generic inks that weren't the right colors.
Jul 09, 2009 | Canon i9900 InkJet Photo Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Wrong colors when printing on photo paper
yha way not
if you worry about wrong colors
it is possible you 3 colors cartage has mis a color it is maybe red,green,are yellow, refill your cartage and print again
Dec 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
Poor photo printing
when the printer says that "for best results use Epson Ink." They mean it! otherwise using Xprint cartridges works as well, if changing the type of ink doesn't work then you might have to tinker with the advanced settings (you can change the amount of color used in the print) when you click the properties button in the print screen, ONLY if you know what you are doing!!
Oct 10, 2008 | Epson Stylus Photo R300 InkJet Printer
HP F380
Try cleaning your ink nozzles or ink jets. It sounds like you have a plugged nozzle or two. Your printer2.gif program2.gif should have maintenance options that allow you to test for plugged nozzles and clean them.
In control panel, open the printing/fax icon, right click on your printers4.gif icon, left click properties, then on the bottom of the page the panel that opens you will see a button that says printing preferences, and that should open your print1.gif program.
This will work for all printers, not just hp.
Nov 07, 2007 | HP DeskJet F380 All-In-One Printer
Epson Stylus Photo R300 InkJet Printer Logo
162 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
