Question about Garden
My stihl chainsaw has no spark. spark plug is new
  • 486 Answers
1) How have you determined that there is no spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 16, 2009
Part # for spark plug wire on stihl saw model ms 180 c
spark plug wires on small engines are normally part of the coil so you may have to get a new coil pack
talk with stihl service parts or service shop
Jul 30, 2016 | Stihl Garden
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
How to test ignition coil on a stihl ms290 chainsaw?
remove spark plug .put new one on to plug lead make good earth.turn ign. on pull over check for a good blue spark.
Jul 06, 2014 | Stihl Ms310 Ms290 Ms390 Complkete Starter...
Chainsaw will only run with choke on and cant get it to idle back
there is a jet inside the carb that is plugged up leaning it out
Aug 18, 2012 | RTO Spur Sprocket For Stihl 017, 021...
Stihl 084av chainsaw manual
You will need STIHL part number 0000 405 0600. This is for one meter of STIHL spark plug wire lead.
Mar 30, 2012 | Stihl Garden
Stihl 025 starts but cuts out have replaced spark plug and new carb
check the spark arrester screen in the muffler. if they stop up it will run like it has
no power and will stall
Oct 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Weak spark hard start stihl 021
Check the pole gap on the ignition module to the flywheel magnets. Use a thin business card for a gauge. If it has the correct gap and you have tried a new spark plug, then the module itself is likely failing. Hope this helps!
Apr 14, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
