Question about Kodak EasyShare CD33 Digital Camera
I lost the usb cable for my camera and am trying to remove images from the internal sd card. how can i do this?
    Scholar:
  • 78 Answers
For your USB
> Contact kodak store at 1 888 369 6600 ask for KODAK USB Cable, Model U-8 or simply log on to www.kodak.com/go/shop.
To remove images from the internal memory of the camera
1. Turn the Mode dial to Favorites
2. Press the Menu button
3. Highlight delete or the minus icon, then press the OK button.
All pictures stored in the Favorites section of internal memory are removed.
4. Press the Menu button to exit the menu
** Kodak CD33 has 16 MB internal memory and it has a slot for MEMORY CARD i lost the usb cable for my camera and am trying - 3428db8.jpginternal memory is different to memory card. You can use the camera without memory card but it's only up to 16MB while if your using s memory card you can load up to SD Memory Card 2 GB.
16MB if camera is set to 2MP it will only take about 2-5 photos while if your using a Memory card with a size of 1GB and camera is set to 2MP about 1137 photos.
* Contact Kodak support line @ 1 800 235 6325 (23KODAK)
Posted on Nov 16, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
You can buy an SD card reader/writer that plugs into a computer USB input. It should appear as a normal external input.
  • loveland88 Nov 16, 2009
My mother in law has a cool pix L120. How does she transfer photos from the cameras internal memory to a SIM card?
The only time the camera puts images on INTERNAL memory is when you do not have a SD card in the camera.
When I have an SD in my Coolpix camera and I want to get the images on my computer I take OUT the SD card and put it in the slot in my computer.
The only way to access images ON the camera's internal memory is to have the Computer access the camera via USB. You should be able to see the camera when you plug it in via USB you can copy images from the camera.
You can copy all of the images on the camera to a folder on your computer.
If you can read the SD card on the computer you can copy the images from your computer (folder you made) to the PROPER FOLDER on the SD card. The proper folder is a XXXNIKON Named folder. (I am assuming you took at least one IMAGE with the SD card in the camera.
Jan 08, 2017 | Nikon Coolpix L120 Digital Camera 14.1mp...
Built in memory full
If your built in memory is full you will want to backup the pictures you have on the camera onto another drive, the easiest way to do this is to plug your camera into your computer (via the USB cable provided with the camera) and transfer all of the files from the camera onto your PC. You can then clear the memory in the camera and begin taking new pictures.
Oct 14, 2013 | Panasonic Lumix DMC-FS6 Digital Camera
How to get the internal pictures off the camera
You need to get another USB cable to get the photos off the camera.
If the photos are stored an a removable SD memory card then you can remove the memory card and insert it into an USB memory card reader and plug the card reader into the USB port of your computer and then copy the photos to your computer.
Apr 24, 2012 | Mustek MDC-5000 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
How do i get internal pictures off my panasonic Lumix DMC-LZ3
If you take the memory card out of the camera, you can view the internal pictures one by one, and delete them, or transfer them to you computer through the cable...they will show up as another drive in Computer, or My Computer, depending on which version of Windows you are running.
Good luck, and hope this helps.
May 03, 2011 | Cameras
Can I download the program to add my A1100 camera to my computer? I've lost the accessories that came with the camera.
You don't need to download anything. You should buy cables that will connect from your camera to your pc/laptop.
Your options are:
Buy a SD/HC card reader. Your camera has a memory card, called SD/HC. Stick that card into a card reader and you can get your images from the camera.
Buy a USB 2.0 cable. Find one that will connect to that of yours, one end is a usb, the other end must match into the camera. (mostly it would resemble a smaller usb port on your camera)
My recommendation:
Buy the USB, its cheaper. You wont run the chance of scratching your SD card when you put it in and take it out of the card reader/camera.
Good luck and Please rate my answer.
Dec 17, 2010 | Canon PowerShot A1100 IS Digital Camera
Hi, i have some photos on my internal memory and need to put them on an sd card because the connection with usb is faulty. As soon as i put an sd card in camera i cant see internal memory images. Is...
There should be an internal transfer from memory to SD card on most camera but not all look under the main menu for the memory card where it tells you to format card and create folders it there should be a COPY option.
Dec 06, 2010 | Pentax Optio A10 Digital Camera
My kodak easyshare C813 is telling me that internal memoryis full. What do I do!
You have to upload your images from your camera to your computer and save and delete the pictures on your camera.
You can buy SD memory card which can store lot more images than the internal memory.
If you will be using the SD card, you have to select from the menu that you want the camera to write images on the external memory instead of the internal memory.
You can upload images on the camera to your computer through USB cable. The cable is cheap if you buy from eBay especially ones that are being sold from Hong Kong.
USB cable from Hong Kong worked well on my Kodak.
Jun 17, 2010 | Kodak EasyShare C613 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Kodak EasyShare CD33 Digital Camera Logo
    126 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
