The digitizer maybe bad. You may want to leave it out without the battery in. use a blow dryer but do not heat it up it will crack the screen. If that doesn't dry the screen out then the digitizer will have to be replaced. hope this helps.
hey
sorry about that.
but from next time if you see that the phone is wet next moment remove battery and dry the phone never charge or try to use the phone with the battery on.
now wat you can do is give the phone for a service. the guy will wash the phone with white petrol and then try starting it. if all the circuits are intact the phone will function back
bye
Try removing the battery, using a blow dryer to air everything out in battery compartment. If there are any tiny screws or way to open up the phone itself, open it up, and blow everything inside there too.
Let it dry out completely and then see if it will work again. My guess is no, because once the circuits get wet, they are pretty much damaged and irrepairable.
key to saving your phone is to not charge it after it got wet. to get it at least partially working take out the battery and take a blow dryer and carefully warm the phone. do not keep the heat near the screen for long periods of time. after drying for about 20mins leave the phone alone plugged into the charger without the battery inserted for about 45mins. after that you can check the results. put the battery in and test to see whats working and what isn't.
Take out the battery....then put it back in. Do not try to turn on the phone yet. Next plug the phone up to charge. Wait until the charging screen appears and then power the phone. Worked for me.....good luck.
take out a battery and check if there is any red paper dots on the back of the phone. If you do have a dot that is at least partially red, that means that your phone got wet and it can not be fixed.
