I couldn't connect to the internet until the router was disconnected and the broadband modem conected directly to the computer.
  • 2,260 Answers
If you connect the modem directly to the computer, it works . that means the internet is working. You will need to check the settings of the router. For this you will need to acces the router set up. Click Here to know more about router set up
Posted on Nov 16, 2009
New modem installed and router won't work now
First step is to make sure if the modem is working. Connect your computer directly to modem with ethernet cable and see if you can log on to internet! if yes
next step connect modem to your router's WAN port with an ethernet cable and then connect your computer to one of the LAN ports of router with ethernet cable. Power down all devices and power up modem first wait until all lights are on and then router wait until all lights are on then your computer! 9 out of 10 times this works! try good luck!!
Sep 23, 2011 | Dynex 4-Port Ethernet Broadband Router...
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
My laptop is conecting but says limited or no connectivity but I have a strong wifi signal
Did a bit of research for you on this and came across a ten step set of instructions which should hopefully correct, or at least narrow down your problem:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
Jan 04, 2011 | IBM ThinkPad X40 Notebook
No internet connection,the wired connection works, the tells me
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
May 20, 2010 | Linksys Wireless-G Broadband Router
I can't connect to the internet
First make sure that you have the router connected properly, meaning you have the ethernet cord from the modem or directly from the wall going into the router portion that says "internet". Try to do a direct connection from your computer to the router to test connectivity. If no conectivity, check the lights to ensure that there is not any traffic broadcasting. If the lights are steady or are off, then there is no connectiviy. Make sure that you are able to access the router interface by connecting directly from the computer to the router. If you are unaware how to do so, click this link and it will give you step by step instructions:
http://support.microsoft.com/kb/331950
Nov 30, 2009 | Microsoft Broadband Networking MN-500...
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
We have a PC conected to the enternet with a modem. We have recently bought an iMac computer and a wireless-G broadband router so we could conect the iMac to the internet too. We have the router conected...
For connecting your mac computer you may need to configure router . What you can do you call call linksys Free Technical support - Direct number is 1800-326-7114
Mar 25, 2009 | Linksys Wireless-G Broadband Router
Asus Router Offline
hello!
-- can you get online if you connect your computer directly to your modem?
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Always disconnect
hello!
-- who is your internet service provider
Apr 17, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
