Question about HP Presario SR1030NX PC Desktop
My computer is acting as is spacebar is being held down, even when no keyboard is attached, and I have no idea whats going on. Can anyone help?
Unistall the keyboard drivers shut down, i would reset the Bios to default and than try a diffrent keyboard or switch to a USB keyboard if you are running a ps2 or even if bios allows to disable ps2 and go straight usb
Posted on Nov 16, 2009
Why does my delete key act like a spacebar?
There are a couple options:
1. Your keyboard is broken, you need to replace it.
2. Try unplugging / replugging it un and or restarting your computer, that may fix the issue.
3. Your keyboard layout might have changed. If you are using a Windows computer, you can press CTRL + SHIFT to switch between layouts. Or you can go to Control Panel -> Clock, Language, and Region -> Change Keyboards or other input methods. From here, you can change your keyboard layout back to use.
Jul 23, 2014 | Toshiba Computers & Internet
Hp probook keyboard
most likley a loose cable or "ghosting" go to your local pc shop for help
Mar 08, 2014 | Computers & Internet
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
I have a mac Laptop and the space button on the bottom of the keyboard is stuck down .. can this be fixed?
It is tricky to repair the space bar. It has a plunger in the middle and is held in place by tension clips. The tension clips are what make the spacebar pop back up. Usually one clip comes loose and the other side still bounces. If the spacebar is stuck down with no bounce, I would check to see if there is something wedged under the spacebar. Get a can of compress air and blow under it, hopefully this will release whatever is under there. Only take the spacebar off carefully without jerking it upwards. If it breaks the clip holder at each end, you will need a new KB.
Good Luck.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 31, 2011 | Apple Computers & Internet
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
Hi, I was using my HP Pavilion notebook with Vista when it froze. The cursor wouldn't move and I was unable to do anything. I tried contol/alt/delete to shut it down, but that didn't work. I then held the...
you could have accidently changed to external monitor with Fn +F(the number is 8 on my comp but could be 5 on yours-check keys on top of the keyboard it has a picture rectangle / little TV), anyways to check that attach external monitor to your laptop(must have a VGA cable) if you have a picture on external monitor try Fn + F(depends on what you have on ur keyboard) it should bring you a window with choices to choose laptop LCD or external LCD choose 1st one .
hope that is it.
Dec 28, 2009 | HP Pavilion dv6000z Notebook
Spacebar stuck
Ok ya gonna haveta get a New Keyboard for ya Lappy... they are relatively easy to replace they are an "All-in-one" thing and usually have a ribbon cable that plugs into the motherboard... ya could disconnect it for now and plug in an external keyboard to ya Lappy to get ya going... But be gentle getting the old keyboard out.. maybe even go online and get a Manual to see how it comes apart.. else it's off to the shop. GL
Jul 29, 2008 | Compaq Presario Notebook
HP Presario SR1030NX   PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
