Question about Cell Phones
Cell phone has alot of static and cutting out
  • kinjalpatel7 Nov 16, 2009
    unlock samsung sgh a-137
Won't read sim
how can i reset my password?
Dec 09, 2013 | Cell Phones
Low volume nsm firebird jukebox
restore your Phone Settings
Aug 08, 2012 | Cell Phones
When you answer a phone call, the person on the line states that they are hearing alot of static for the first couple seconds
This is due to the activation of conference call.You have to disable it,when it is not needed.
Aug 11, 2010 | LG GW525 Cell Phone
There is alot of static on the phone
Try another phone or get your phone co to check the line.
Mar 05, 2010 | Panasonic Lands Phones
Nokia 6110 - Can hear callers but they can't hear me
Sounds to me like a microphone issue. Try contacting the Cellular Dr./ Cell Phone Dr. , or Cell Phone Repair.com. They both do excellent work as far as cellular phones go. I am a Satellite Phone Technician, although I have done alot of Cell phone service and repair as well. If you ever need a satellite phone repair done, or want to rent one for a trip to the middle of nowhere, call us at 206-329-1947
Feb 18, 2010 | Nokia 6110 Cellular Phone
Phone line static
with the modem disconnected and the static is still there , indicates a problem service land line
ask your service provider for a line check because of the noise
Nov 22, 2017 | Motorola Mobility MD481SYS Cordless Phone
Terrible static on 2.8Ghz 2-line phone Model EX 13226
do you have internet plugged in to it. You may need a microfilter which you can buy or if they came with your router .try it
Jun 25, 2009 | Uniden Cordless Phone
Razr Cuts Off During Calls
take the phone and have it check
Jun 21, 2008 | Motorola Mobility RAZR V3
Razr v3r lcd
I would first try resetting the phone through the settings menu. Make sure you backup your data first, since the reset will wipe it clean.
If that doesn't work, you most likely have a loose cable inside of the phone. You can take it apart yourself and find the culprit, or take it to a shop for a cheap repair.
Dec 17, 2007 | Motorola Mobility RAZR V3
Constant static and interference
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
Cell Phones Logo
81 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
