Question about Linksys Wireless-G WRT54G Router
Tryin to install router, but it says ethernet cable not connected? not good with computers,
  • 1,305 Answers
You should have an ethernet cable between your modem and your router. If it's dsl or cable, either one will have an ethernet cable (looks like an oversized phone jack with more connectors).
BUT this is the important sequence to follow.
Assuming that your modem is working properly already, connect the ethernet cable between the router and the modem. then turn OFF both pieces of hardware AND any wireless computers. THEN turn on your Router first and let it boot all the way. Then once the router is booted, turn on the modem and let it cycle up.
Once this is done, you can turn on all the other computers etc on the system... that should get you up to working status!
Posted on Nov 16, 2009
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
New modem installed and router won't work now
First step is to make sure if the modem is working. Connect your computer directly to modem with ethernet cable and see if you can log on to internet! if yes
next step connect modem to your router's WAN port with an ethernet cable and then connect your computer to one of the LAN ports of router with ethernet cable. Power down all devices and power up modem first wait until all lights are on and then router wait until all lights are on then your computer! 9 out of 10 times this works! try good luck!!
Sep 23, 2011 | Dynex 4-Port Ethernet Broadband Router...
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
Can.t connect to the internet using a wired connection..
If you're just pulling the ethernet cable off of the back of your computer, it won't work. You'll need a router connected to your network first, and then connect the 360 to the router with a second ethernet cable after setting up the router.
step by step.
1. connect the ethernet from the modem to the router.
2. connect the small ethernet that came with the router to the PC.
3. insert the cd that came with the router and follow the setup.
4. plug the 360 into the router with an ethernet cable into an empty port.
5. enjoy.
If you have a router already, you may just want to check the ethernet cable for any breaks. easy way of telling if it's the cable is to simply use a different cable, or use the cable for a different device, like your computer. change the cable out with a good one and see if you can still get online. If so, then your cable's not the issue.
If you have a router, good cables, and it's still not working, you may need to have the 360 looked at by a licensed repair service, because the ethernet jack on your 360 may have went out. This is rare, but it's possible.
Mar 01, 2009 | Microsoft Premium System for Xbox 360
How to install a linksys router to my desk top for my wireless laptop
1. plug in the router
2. connect the router to your DSL or Cable Modem using the supplied ethernet cable
3. connect the router to your computers ehternet port with a second piece of ethernet cable
you can use catagory 5 ethernet cable , or catagory 6
Most linksys routers have 4 to 5 ethernet ports to connect computers to.
One of the ports will be marked as the one to connect to your DSL or Cable Modem
Usually when looking at the back of the router the WAN port will be located to the far left.
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Computers & Internet
Hard ware problems
HI Barry
You need something called an ethernet cable. One end of the cable goes in the router and the other end goes in the ethernet poet of the computer.
This is an ethernet cable
512c92e.jpg.
This is the network port (ethernet) of the PC
If you dont have an ethernet port on ur pc u may need to pay an ethernet pci card like this and get it installed on your computer
Hope this helps
Cheers
JigSaw
XoXo
Aug 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router not being recongized
if your running windows xp then you should remove any programs that you installed to run router then look into hardware manager and uninstall router and restart computer . then try once again plug in router once comp boots and let win xp load the correct drivers if this doesnt work go to windows update website and get all available updates including all hardware updated then try installing again good luck with it
Jul 13, 2008 | D-Link AirPlus DI-524 Wireless Router
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
