Hitachi 50ex8k rear projection year 1994. How do i get the picture to line up right? alot of knobs and cant get it right.
  • 1,210 Answers
You will need a signal generator. And need a convergence map to trouble shoot alignment. But before you attemp this, you probably have some bad solders on the potetionometers that tweak alignment. Or you will need to replace the correction ICs. I suggest you take your tv to a tech.........As you may want to do this yourself....this is a big mistake. Get help....profesional help!
Posted on Nov 16, 2009
Pip won't turn off
PIP for this model is usually only via the rear audio/video jacks---if using a cable or sat box look there as they also now have that feature
Dec 03, 2012 | Hitachi Televison & Video
I have a Hitachi 50EX8K. I believe I have a convergence problem. Colors are blurred, and the picture is pulled in near the center at the top and bottom of the screen. It would happen rarely, and recover...
Sounds like a convergence failure, it was initially probably just loose connections but now it needs new parts, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 09, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Why does my picture have a red cast the over all picture has red
Open the front panel until you see 3-6 knobs, adjust those knobs until you get the right picture.
Jul 19, 2010 | Hitachi 50UX57B 50" Rear Projection...
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
I have a Hitachi 50EX8K projection TV that will not turn on. When you hit the power button you can hear a "click" but nothing happens. I have some electrical knowledge and could use some help pointing me...
if this is projection tv that clicking sound it could be the ballast tryin to turn on a burned out lamp or the ballast could not be sending the right amount of voltage for ignition, you can check the ballast if its liking oil or if you see something burned in the board.
Apr 15, 2010 | Hitachi 50GX30B 50". Rear Projection...
The set is a Hitachi Ultravision Digital Model #57XWX20B. The picture "Ghosts" red. When runnung the Magic Focus, it stops on the 5th red line and goes no further. In low light scenes, it blacks out in a...
The Convergence IC's need to be replaced. They are located on the Board to the right, mounted on a large heat sink. They should be replaced with STK392-150's. The original IC's are probably STK392-110's.
The Stk392-150 is a updated replacement. Be sure to use Heat Sink Compound between the IC's and heatsink because these IC's do draw alot of current and heat up alot. Also look for any heat stressed Resisters.
I hope this helps,
Sky Assoc
Feb 07, 2010 | Hitachi Director's Series 57XWX20B 57"...
I cannot get my Hitchai 50EX8K aligned. There's a
replace the convergence amp ICs and also check the low ohm resistors
May 17, 2009 | Hitachi 50EX20B 50" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Hitachi 57f500 Rear Projection HD set
sounds like you have a bad soldering in your horizontal deflection circuits go check your circuit board for dull solder anything thats dull resolder if that doesn't solve your problem your deflection circuit will need to be diagnosed let me know if I can help you further
Apr 11, 2008 | Hitachi 57F500 57" Rear Projection...
HITACHI PROJECTION MODEL53FDXO1B CONVERGENCE PROBLEM
Replace both IC's with first quality Hitachi upgade STK394-160
part # CZ 01341 and inspect near-by resistors for over-heating.
.......................T.
Feb 15, 2008 | Televison & Video
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
