Question about Optoma HD65 DLP Projector
A flickering on the screen looks like a hair.
My hp 3222 model projector it is now when i power on after some time it is lamp is flicking and screen is become red
Posted on Nov 16, 2009
Flickering Sharp Aquos tv
it really depends on were the flicker is, if its the backlight or the screen, flicker can mean them both, t-con board only controls the screen out put on lcds, but on plasmas it works with the back light inverters. if the screen is white and not flickering while looking at the back of the screen on an lcd then it could be the t-con board failing it could also be a bad connection to the board from the wires. the plug were the main board connects to the t-con board if you have the back off and wiggle the cable and see if it stops the flicker.
Aug 08, 2017 | Sharp Televison & Video
How to fix Toshiba Rear Projection Television
check colour wheel needs replacement bearing are worn out
Jul 13, 2013 | Televison & Video
Screen doesnt work
PCB board probablly have mirco hairs cracks or big cracks.Ur LCD viewing screen is in question too.Not worth,fixing.The price of the tech. the components dies in the drop impact are many variable to solved.
Jul 21, 2010 | Polaroid DPA-08040B Portable DVD Player
Acer Laptop Screen Flickers & Jumps
Please connect the laptop to an external monitor. If no flickering on monitor screen, from my previous experience, this is more likely loose connection of video cable connected to the LCD. So talk to Acer support again and require the replacement of LCD.
CompQ
May 11, 2010 | Acer Aspire 6930-6082 Notebook PC
Lg env touch internal screen flickers white/colors after h20 expo
go ahead and take it apart... but be extra careful with the flex part,, dont use aclohol it may corrode some parts, try using lacquer flo, and dry it out with mild heat using hair blower or some sorts
maybe that would fix it, but if the lines you are saying doesnt go off, well you have no choice but to replace the lcd itself
Nov 10, 2009 | LG enV VX9900 Cellular Phone
My screen looks like the tracking off. It wount stop flickering
Some electolytics on a small regulator IC are going bad. Take it to a shop.
Apr 30, 2009 | Mitsubishi VS-60707 60" Rear Projection...
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
42 inch screen
Did you measure diagonally from corner to corner? This is usually how all manufacturers quote screen size. Hope this helps
Dec 07, 2008 | Polaroid FLM-4201 42 in. LCD Television
I have a clear bright green vertical line on my laptop screen
This sounds like the LCD inverter it could be getting ready to go, usually you will start seeing flickers as well, it may just be a faulty connection in the LCD either way, it's best to have someone look at it before the display goes all together.
Hope this helps
Dec 05, 2008 | Toshiba Satellite P30 Notebook
T41 screen intermittantly flickers then locks up
BGA RAM For the Video chipset is the problem.. Weve repaired a few of these..(Wish I could tell you its an easy home fix but its not)..
ikenfixit.com
Jan 24, 2008 | IBM ThinkPad T41 Notebook
Optoma HD65 DLP Projector Logo
237 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
