Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Will not drain
Ge nautalis disshwaher will not drain... click suggests it will then it will not... please help!!!!
  • Anonymous Apr 21, 2008
    Same thing....have a ge nautilus dishwasher, just turned one year old a couple weeks ago and I opened it to empty it, and there was water in the bottom. Nothing is drianing now. What do i do? Where do I look?
    President:
  • 4,402 Answers
.first thing to do is to see if the drain motor is running or not....if it is running but not draining the water the hoses and drain pump motor should be checked for any restrictions right from the drain pump assembly/motor all the way to the sink/house drain.
If the drain motor assembly is not running, is it receiving power, is it jammed up with something ( glass, pits are common ).
Posted on Jan 09, 2008
Washer won't drain!
Sounds as the pump has gone wrong, if it's turning & doing the usual cycle except for draining the motor is fine, check the pump filter trap to be sure there is no obstructions as a simple penny can stop the pump motor turning preventing the machine from draining, I hope this helps.
Jan 24, 2018 | GE Spacemaker WSLP1100D Top Load Washer
I have a 16 yrs old fridge that's dripping (what appears to be) condensation from the control unit area. I do not see an obvious leak behind the control cover. I was happy to see the Technical Data...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 25, 2011 | GE Profile 21.6 cu. ft. Top Freezer...
Problem with the GE Monogram ZISS420DMSS Side by Side Refrigerator. Defrost Drain tube clogged. Icicles form in the frezer compartment. How do I fix? Thanks.
Leo Ponder
imufo2
Aug 17, 2011 | GE Monogram® ZISS420DMSS Side by Side...
I have a built in GE model GLD4400N10BB and it is not draining properly. Instead it is leaking from the bottom (looks like from the flood float) into the floor. It is 4 days out of warranty. Any...
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
Jul 20, 2011 | GE 24 in. GSD4020Z Built-in Dishwasher
I have the GE 206c1513p001 Potscrubber and recently found a black seal or rubber band in the dishwasher. Since then, it has been making a continuous clicking noise when it is run and does not clean the...
I have the exact same problem!!! Found 2 loose rubber bands, the bottom doesn't drain completely, and the dishes are left either dirty with a white film on them. Please help!
Oct 06, 2010 | GE Dishwashers
Dishwasher not draining, not getting dishes clean. detergent still present in its space, filters at the bottom appear clean and hose to drain appears unclogged Nautalis GE 24"
sometimes this drain motors get stuck..you have to turm them a couple times with your hand, make sure you shut off power....also sounds like you have problem with cycling...i wish a can take a look on it....turn you drain pump...and try to start again see what is goning to happend....please let me know you results totalcarefl@yahoo.com
Aug 25, 2009 | GE Nautilus 24" Built-in Dishwasher
Water standing in the dishwasher at end
probably cant fix this your self. if your sink is draining ok then you probably have a problem with your circut board.
Apr 25, 2009 | GE Nautilus 24" Built-in Dishwasher
Ge Triton XL Dishwasher Fill Problem
I would check your fill valve screen, where your water line connects to the dishwasher, lots of times i will see that screen clogged, especially on customers homes that have wells.
There is no way to change the fill time on these.
There is also the potential problem with the float sticking if it is gunked up it will not allow water in...see that it moves up and down freely and you should here a clicking noise.....If it is not one of these there could be a problem...with the timer...I am providing a link that will help walk you through this problem in a more technical...manner...if you are not comfortable performing these tests...i suggest you forego it and let a tech handle it....
http://www.applianceaid.com/dish.html#filling (http://www.applianceaid.com/dish.html#filling)
this is one continuous link.....you can scroll down until you see the won't issue.
I hope this helps ..good luck, have a good day& please rate my effort......The Fang
Dec 31, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
217 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
