Question about LG DLE2532W Electric Dryer
All is working fine on LG DLEX7177 Dryer, but no heat. I've checked lint trap and connection which are not blocked. Should I try the reset and if so, where is it?
  • kristin_hall Nov 16, 2009
    This doesn't help much. All is working, but I need to know what to do for my LG model DLEX 7177. Though the dryer works fine, there is no heat to any cycle. I need to know how to reset this model.
    Thanks,
    Kristin
  • 11,896 Answers
Check with an ohmmeter or voltmeter the power leading to the heating element. If there is power, then element is probably bad. If no power, then a relay or selector control may be faulty. \
repair2000.com/dryer.html
Posted on Nov 16, 2009
  • 986 Answers
Here are a few more recomendations as well as waht you tried.
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
  • Roger Campbell
    Roger Campbell Nov 16, 2009
    LOL Kristen.
    you checked all of these parts with a Ohm meter??? I feel you are over looking something. I know for a fact that it is only one of these. house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug. Evedently you are just cruising for a easy answer that will not appear. Maybe you should look at what you have and troubleshoot the equipment and tell us your readings. Maybe only then can we decide what your issue is. You have missed something or just dont understand waht your looking at. Hope it works for you. I dont think it will till you listen and troubleshoot not just assume you are right. Been doing this for 20 years. I know what Iam talking about. To bad you know more than us. Best of luck.
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Hi there, I'm hoping somebody can help me out? I have a washer/dryer and the dryer is not working. The drum rotates but does not heat up and the clothes are still very damp/wet Whilst the washer...
There are several reasons why a dryer would not heat up the clothes.
  1. The vent is plugged with lint or the blower set-screw is loose (blower slips on the motor shaft instead of spinning full speed). If you do not have good airflow at the outside exhaust when the dryer is running, you'll need to check the ductwork all the way back to the lint trap. If the lint trap is torn, repair or replace it.
  2. The heaters are not working due to a bad contact in the timer or one of the two thermostats. Check for continuity in the heater circuit with the dryer unplugged.
  3. The heaters are burned out. Note the plural - most dryers have two heaters, one for low heat, the other for medium, and both for high. Try a different heat setting and see if you get warm air. If you do, the heater you normally use is the problem.
Jul 03, 2011 | Hoover Washing Machines
My dryer says check filter? Where is that at?
Lint filter,, usually a slide out screen,, some are in the lower opening by the door
May 26, 2011 | LG DLEX7177 Dryer
Just moved the dryer to new home after having it in storage for 18 months. Plugged it in and it doesn't do anything. Tested house circuit and it is fine. Tested the dryer at the cord connection and it is...
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
as seen on heatmans blog
Apr 29, 2011 | LG DLEX7177 Dryer
LG DLG2532 dryer not heating up, lint trap clean, good air flow out exhasut vent, all controls seam to be working i.e. lights on buttons and chimes good, seams like its not getting gas but valve is turned...
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 16, 2010 | LG DLE2532W Electric Dryer
My electric dryer runs for awhile then it just shuts off after about 15 minutes of running? Its a neptune.
a couple of things here may be the problem.. First I would check to make sure my lint trap and the dryer exhaust is not full of lint causing the dryer to heat at a higher temp throwing the high limit switch into disconnect due to the amount of heat generated by the coils. This hi limit switch is a safety device to prvent fires. If you find a lot of lint in the dryer vent or the dryer lint trap, once cleaned, see if the machine doesn't operate like you want. Second. The motor bearings or strator may be going out and the motor is going into thermal overload and shutting down to prevent, as you guessed, a fire. I would check the lint trap and dryer exhaust first since it is more than likely the problem and is cheaper to fix. A wet/dry vac should do the trick. Also remove the back of the dryer to clean out the lint paying special attention to the area around the motor vent which can get blocked causing the motor to over heat. Once these vents are cleared the motor may be fine. Make sure to do all of the above with the dryer disconnected from the power source..
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
The dryer runs fine, but there is no heat. I
You will find the heating elements on the driers are very robust. Normally what happens is there is either a build up of lint which has possibly blocked the air inlet grid,.or possibly being to close to the wall. This in turn restricts cooling airflow .There is a thermal protection thermostat which will activate and open circuit if temperature is exceeded at any time.Need to locate the thermostat and if lucky, you could simply press a button and it will reset. If not, you may need to replace that defective one. Typically the thermostat is at the back and close to the element.
Sep 28, 2009 | Whirlpool LER5636P Electric Dryer
LG Dryer Sensor
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again
Sep 27, 2009 | LG DLE2514 Electric Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Plugged venting causing low heat and poor lint output?
you need to check the dryer vent hole on the back of the dryer,make sure it's not blocked,also check the wall vent for the same thing,most of the time if there is a clogg it holds the moisture in the dryer and it take forever to dry,you can use a shop vac to **** out any clogged lint in dryer and wall ,then if you have a leaf blower put it on the wall side and blow it it all out.let me know how you do-mike
Oct 30, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
