Question about GE (PSS26MSRSS) Side by Side Refrigerator
How can I fix my refrigerator.. i made a hole in the freezer, the freons i think came out, then, all of a sudden our freezer didnt release colds..is it out of order, can we fix it?how?
  • GE Master
  • 43,501 Answers
Depending on where the hole is a sometimes it can be repaired. Often they connot be economically repaired. You will have to call a repair service to come a look at it to see if a repair is possible.
Posted on Nov 16, 2009
ISN'T GETTING COLD NEED TO KNOW HOW TO ADD FREON PLEASE ?
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
Dec 21, 2015 | Amana Freezers
Freezer not cold, refrigerator is cool. Everything melted in the freezer. No ice
Causes of that is temperature control is defective or undercharge freon, clogged dirty particle inside the system of your refrigerator, it need to be clean by flushing the system, sealed the hole in tubing before it can be recharge with freon.
It's complicated to do, so call a refrigerator technician to do that.
I hope I give you idea concerning your problem with your unit.
Jun 11, 2011 | Jenn-Air JSD2789GES Side by Side...
Freezer isn't cold, defrosted all of my food and the refrigerator part doesn't seem very cold either.
If your refrigerator cooling doesn't seem to be working well, and you have no idea what to look for in troubleshooting your problem, there are some things you can do to try to figure out your problem without paying a serviceman to come into your home.
Freezing
Most new refrigerators come with automatic defrosters. Although this is a standard feature the drain hole in the defrosting assembly can get clogged with debris, lime, or even ice. If this happens the defrost will not work and there will be a build-up of ice in your freezer that begins to block the freon from flowing properly and causing heat to react improperly and cause your refrigerator to stop cooling.
Freon
Freon systems in a refrigerator are closed systems but on occasion you may need a recharge. Refrigerators use R-134a freon, just like in an automobile. The old R-12 freon is no longer available, so if you have an older model of refrigerator you will not be able to obtain the freon, and it will be recommended that you replace that refrigerator.
Seals
The seals that are on the door of the refrigerator and freezer can dry rot with time. When you begin to see the seals cracking or warping, if your refrigerator opens more easily than before, or if you see the the door does not close fully without pushing on the door then the gaskets around the doors will need to be replaced. They are held in place by clips and the replacement is an easy fix.
Holes in Lines
Let's face it, many people find ice in their freezer or the back of their refrigerator and will try some self-help without knowledge. They will grab a knife or fork and start chipping away at the ice. This is extremely dangerous. There is a great risk of puncturing a hole in the freon lines by stabbing at the ice. Since freon has the purpose of cooling most ice collects the thickest on the inside of the walls with the freon lines right behind the plastics. A better method of removing the ice is to empty your refrigerator, turn it off and leave the door open. If you want to speed up the process you can turn on a blow dryer and aim it at the edges of the ice. If you aim at the edges you will warm up the ice and create warm water which will flow down and help to separate the ice panel from the wall.
Uneven Refrigerator
If a refrigerator is not even on the floor it may not close properly. Rock your refrigerator and see if it seems to topple from one foot to another. The feet on a refrigerator can be adjusted by screwing in or out and leveling each foot individually until they are all even.
Non-Problem Warming
If your home is hot your refrigerator will work harder. If you put a lot of food in your refrigerator and freezer, your coolant will have to work harder, and it will seem to take longer to cool. It is just that there is a lot of food that is trying to freeze or maintain cool temperatures.
Good luck
May 31, 2011 | KitchenAid KSRK25FVMK Stainless Steel Side...
Freezer & refrig not cold
change the filter. to do this recover the freon(gas), remove the filter , replace it by new one; do the vacuum and then charge again. Work must be done by a certified technician. do that at your own risk
Aug 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Re: Sanyo SR4310W mini fridge freezer plate broken
Ok, I know I should not have done this but I did. I was impatient with the defrosting and stabbed my Sanyo SR3770s' evaporator with my Smith and Wesson switch blade knife. A very tiny hole, made a swooshing noise and now the fridge won't get cold. Can this be repaired for a minimal price? Perhaps just replacing the evaporator plate and reinstalling some freon, maybe, hopefully?
Let me know. Basically a brand new unit, hate to see it go to the dump!
Sandra
Jul 20, 2009 | Sanyo SR-4310 Compact Refrigerator
GE Side BY Side keeps Running
two reasons I can think of, fan motor because of the whining description you descibed, and possible freon leak. I think the first is the problem!
Dec 27, 2008 | Refrigerators
My refrigerator/freezer isnt getting cold enough
The problem usually isnt in the freon it usually is in the defrost system located in the freezer.I guess you have got this fixed by now and Im sorry for taking so long to get back to you but I havent used the computer in about four months because of family emerg. if you have any more problems let me know.
Sep 29, 2008 | Kenmore 53092 / 53094 Side by Side...
I was trying to defrost this college sized refrigerator. I was using a screwdriver to try to break loose the ice build-up around the top freezer section when all of a sudden a heard a noise and steam...
Sure do you broke open the Sealed system this is where the freon (gas that cools the unit ) is you released gone forever...
Now you will need to have some one out to fix the hole vaccum down the system and recharge it but most likely just buy a new unit due to the cost involved in the repair. Live and learn never to use sharp objects in a freezer...next time use a hair dryer to unthaw
Jul 30, 2008 | Refrigerators
Ice forms in the section on top of the refrigerator
Judging by a similar problem I had with a dehumidifier, you may have a Freon leak or low freon pressure - (It's probably NOT really FREON - but something else).
This is a fair guess - from my dehumidifier problem. A dehumidifier functions the exactly the same way as a refridgerator - except it's not designed to "keep the cold in a BOX." Given the cost of a service man AND the cost of the Freon (it's expensive), you may want to pitch the Fridge and get a new one.
Mar 13, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
Kenmore fridge not cold
You might have to have a repairman check the charge of freon in the system.
Nov 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
