Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Suction from hose isnt strong enough. Vacuum
The suction from hose(when detached( isnt strong enough. Vacuum works great otherwise!
    Problem Solver:
  • 14 Answers
There is probably a clog on the U channel (little Gray tube that attaches to the Vac tubing). Pull it loose and look in side all the tubing.
Posted on Nov 17, 2009
  • lolivas
    lolivas Jan 28, 2014
    not every pass is free of any restriction
Very low suction when I use the hose, but the carpet brush roller attachment works fine. Any ideas?
This style of vacuum has great airflow but does not have great suction, especially at the end of the hose but it still should have enough to pick up most soils. It may have a restriction in the suction tube or emptor. The disposable bag may be full or clogged, the outer bag could also be clogged.
May 04, 2016 | Kirby G4 Bagged Upright Vacuum
Why when I Pull out handle to use edging attachment, suction stops?
Make sure that the vacuum cleaner is in the fully upright position as there is a slide 'gate' thet directs suction to either the vacuum head or to the handle section depending as to which section you wish to use. In the upright position, you shoud be able to hear the vacuum at the handle where the attachments connect. If you still have vacuum at floor level, check the action of this gate. The actuating mechanism may be broken. Cheers Bob
Jul 12, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
NO SUCTION
You haven't given enough details of what machine you are asking about. Take it to your local vac shop for help.
Aug 08, 2017 | Dirt Devil SwivelGlide Bagged Upright...
Hoover U5750-900 hose suction not working
Sounds like the section from the hose to the bag may be plugged. Or you may be losing vacuum due to a leak in the hose. Hope this helps.
Mar 03, 2014 | Hoover U5750-900 WindTunnel Bagless...
My Dirt Devil Vibe bagless vacuum started giving off a burning smell. The brush roller was jammed with hair. I immediately shut it off and cut the hair out of the rollers with scissors until it turned...
It's more likely there's a clog in the hose somewhere, possibly where it connects to the power nozzle. Detach hose and check the PN.
If there's no clog in the PN, detach hose completely from machine and try to drop a marble or coin through the hose. If it doesn't fall through, there's a clog that needs removed/cleared. Hold PN end of hose tightly to tank of vacuum and turn on. That may be enough to **** the clog through. If not, use a canister or shop vacuum to blow the clog out.
Nov 13, 2010 | Windsor SR12 Sensor Bagged Upright Vacuum
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Vaccumn repair ...lostlosing suction, belt still turning roller bar, hose clear
To generate strong suction, the motor has to turn at a good speed.If its a bag vacuum change bag with new one when a great deal of debris builds up in the vacuum bag, the air faces greater resistance on its way out.
Sep 12, 2009 | Vacuums
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
Mar 05, 2008 | Hoover F5858-910 SteamVac Vacuum
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
193 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
