Question about LaCie (300728U) 250 GB Hard Drive
Can't access my lacie external hard drive
my external Lacie 250G (almost full) has stopped being recognized when i turn it on. I mean the computer (windows vista) recognizes a new device (sound alert) and when i click safely remove hardware it states that the device is working properly. But i cannot access the drive - i get the message that i have to format the drive, because it has not yet been formatted. Plus it does not recognize it in "computer" as Lacie drive as it did before, neither does the autoplay start - not even manually.
Help would really be appreciated. Thx
  • joybro2000 Jan 09, 2008
    Thanks for the prompt reply!
    The drive does not work on a different PC, so I will go and purchase the enclosure plug in and report back.
    Thx again
  • Anonymous Mar 12, 2014
    Cannot find it in control panel or access the External HD in any way that I know of. How can i make it recognizable and accessible.
  • 233 Answers
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Posted on Jan 09, 2008
If I try and format my LaCie drive through my computer its capacity shows as 9.99 MB why is that if I do format it (NTFS) will it have the correct capacity of 250G
You may have two or more partitions on this hard drive. If you delete all the partitions and then format the hard drive then you will have the full unformatted 250 Gb capacity.
Sep 24, 2010 | LaCie (300770) 250 GB Hard Drive
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
First time trying and i cannot access my data. This is the first time I tried to pull it up.
USB is very finnicky. Shut off your computer and external drive. Unplug the USB cord from one end (which ever is easiest). Turn on your computer. When windows is up, plug in USB cable. Turn on USB drive. Windows should recognize the USB ox and drive and attach the extra drives. But, you must have windows millenium or newer. Or you will need USB drivers for the external USB box.
May 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
External hard drive
I just worked through this same issue with LaCie tech support and they fixed it- it was a bad power supply. Fortunately I had another LaCie drive and when I plugged the power supply from that one in to the "misbehaving" drive, everything booted up fine.
Sep 20, 2008 | LaCie (300770) 250 GB Hard Drive
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Computer does not recognize LaCie or give me a drive letter for it
is it a usb? have you tried another usb port?
you may need to remove the usb ports from the system and have the computer reinstall ( make sure you have the correct drivers before you do that).
Apr 11, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie (300728U) 250 GB Hard Drive Logo
1,032 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
