Question about Runco CL-410 Multimedia Projector
I have a Runco CL-810 projector that after powering, the projector starts, the runco image appears on the screen, and after 10 seconds, the projector powers down and the lamp light turns on. When I unplug the unit, it again resets, the projector powers, the lamp lights, the projector then powers down and the lamp lights again. is this a software issue or other problem. The lamp has less than 100 hours on it.
3 Suggested Answers
  • 14 Answers
SOURCE: My Runco CL-410 projector runs
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
Posted on Feb 28, 2011
  • 14 Answers
SOURCE: My runco cl- 410 projector
most likely you have a bad lamp
I have a Runco CL-810 projector, how do you clean the fan filter?
Filter will be located near the intake fan. You can remove it and clean it. Normally just blow out the dust. If it is oily you can use dish soap be sure it is fully dried before replacement. The fans you can blow out (with machine off) Be sure not to spin them too fast or the bearings will be destroyed.
Dec 16, 2012 | Runco Cl-810 Reflection Dlp Projector Lens
How do I replace the bulb hours in my Runco Media VX-4000d Projector? I already replaced the bulb. Thank you for your help!
Please contact Runco support at 1-800-23-RUNCO. We can assist you.
Sal Di Giacomo
Runco International
WW Service Manager
sal.digiacomo@runco.com
Aug 05, 2011 | Runco VX-5000ci Multimedia Projector
My RUNCO projector is projecting upside down and we cant seam to fix it. Any advice?
1. Press the menu button on the remote to bring up the on-screen menu. 2. Select the Setup Menu 3. Select Picture Orientation 4. Change the configuration so that the image and text appear correctly.
Feb 28, 2011 | Runco Reflection VX-1c Multimedia...
My Runco CL-410 projector runs for about 30-45 seconds, then the lamp turns off. The hour meter says it has 471 hours on it. Any ideas?
Jan 09, 2011 | Runco CL-410 Multimedia Projector
Unit not powering up. New lamp installed but
a couple of things did you reset the lamp timer? Sometimes if the panel door lamp is open or not closed you will not be able to power up. Have you tried removing the lamp and reseating it? Perhaps the fuse is blown...you will need to remove the cover and look to see. fuse should be located in the area of where you plug the power cord again you will need to remove the power cord.
Jun 02, 2010 | Runco CL-510LT Multimedia Projector
Runco CL710 Pass code required
I have the passcodes pdf for most models, let me know..
Feb 03, 2009 | Runco CL-410 Multimedia Projector
Need to adjust from full screen to wide screen on Runco SC3050
You need to use the remote, press the Menu button... on the menu that pops up on the screen, use the remote to scroll down to where it says "aspect ratio", and then select enter.
From that menu, you can select all the different aspect ratios that your Runco can perform.
Here is a link for the owners manual, straight from Runco.
http://runco.com/legacy_prods/legacy_manuals/CL-510_510LT.pdf
Oct 11, 2008 | Runco CL-510LT Multimedia Projector
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
119 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
