Question about Insignia NS-LCD47HD-09 47 in. LCD TV
I have a 37" Insignia L37Q tv with 4 HDMI inputs. Only HDMI 1 works properly. If I hook up an HDMI device to any of the other HDMI ports I get one of the following: 1. No signal 2. Not supported 3. Picture with no volume Every HDMI device I have works properly on HDMI 1.
  • wcunningh629 Nov 16, 2009
    The first response was beyond ridiculous. Why buy another HDMI selecxtor switch when I have 4 HDMI ports? I want the ones I have to work. Right now only HDMI 1 is operational. And I have the manual so a link to a manual is redundant!
  • 3,741 Answers
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 16, 2009
I get one problem I get one receiver satellite I put the cable for hdmi1 I didin't see nothing one the screen
Posted on Oct 11, 2011
My power board is good -need to troublesshooting my mainboard for insignia 37 inc
This is so cheaply done it is a waste of time to troubleshoot it.
Just replace it, it's going to end up costing less than trying to troubleshoot that.
Oct 02, 2012 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
Tip
REMOTE CONTROL CODES FOR THE INSIGNIA TELEVISION MODEL: 37" NS-L37Q-10A
This information was found on the Insignia website. www.insignia-products.com under technical information for the insignia television model number 37" NS-l37Q-10A cablevision-ur2-cbl-cv04.gifaligner.gif CableVision UR2-CBL-CV04
code: 096
charter-digital.gifaligner.gif Charter DIGITAL
code: 0463
comcast-m1057.gifaligner.gif Comcast M1057
code: 0463, 10463
cox-cox.gifaligner.gif Cox COX
code: 0463
direct-tv-rc23.gifaligner.gif Direct TV RC23
code: 10463
dish-network-vip508.gifaligner.gif Dish Network VIP508
code: 720
dish-network-vip622.gifaligner.gif Dish Network VIP622
code: 720
motorola-drc800.gifaligner.gif Motorola DRC800
code: 0463
one-for-all-urc-6690.gifaligner.gif One for All URC-6690
code: 0464
phillips-pdvr8.gifaligner.gif Phillips PDVR8
code: 115
phillips-ph5dss.gifaligner.gif Phillips PH5DSS
code: 115
phillips-ph5dvd5.gifaligner.gif Phillips PH5DVD5
code: 115
phillips-pmdvr8.gifaligner.gif Phillips PMDVR8
code: 115
rca-rcu807.gifaligner.gif RCA RCU807
code: 135
rogers-dct3250.gifaligner.gif Rogers DCT3250
code: 0463
shaw-dct3416.gifaligner.gif Shaw DCT3416
code: 0463
sony-rm-vl600.gifaligner.gif Sony RM-VL600
code: 8043
tivo-hd.gifaligner.gif TiVo HD
code: 0091
tivo-series-3.gifaligner.gif TiVo SERIES 3
code: 0091
on May 23, 2009 | Insignia 37" LCD Flat-Panel HDTV
I have a Insignia NSL37Q10A, when you turn it on it display's
Change input device to some other like a DVD player. Look for loose contacts in RC jack, cable, sockets. Look for any jammed buttons on TV or on remote.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 03, 2012 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
I continue to have to switch my HDMI cable between 2 ports on my TV because initally there is "no signal". But when I switch ports I get a signal. So is this a HDMI cable issue, port issue or my Insignia...
My best bet would be a port issue - see if another device will work plugged into that port. (Some HDTVs have a HDMI port strictly for Service and nothing else but a Technicians specified cable will work in this port, look at the Manual) Check to see if your TV is set to the same port as your connecting to. One will be HDMI 1, next HDMI 2 and so on, the input button on remote should switch from port to port, make sure port setting on TV is same as #port your connected to.
Jun 17, 2010 | Insignia NS-BRDVD Blu-Ray Player
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Have hooked up HP Pavivillion PC with HDMI cable; get no audio, picture is fine. How do I get the audio to the TV??The TV is a new Insignia NS-L37Q-10A.
Plug in the HDMI to the TV and set the TV to HDMI input. Go to the Vista Contol panel on the PC, to Hardware & Sounds, then Sound.
The control panel will show the computer speakers as the default hardware. Highlight the HDMI icon, click the Default button! That's it: obvious when I realized "default" was not "return to default settings", but setting the default device. Duh... always simple once you see it.
Thanks, Rick Russell
Nov 13, 2009 | Insignia LCDTV26 26 in. Television
Screen went blank after hooking computer to it
Let's cover the obvious.
The TV works fine with other inputs (cable TV), right?
The laptop is plugged into the VGA port on the TV and the input setting is set to "VGA", right? (or does toy computer have an HDMI port that you are using?)
Is it a laptop or a PC?
If it's a laptop and the TV is connected correctly and functioning otherwise, you need to turn on the remote display port of your laptop. It's a key sequence that toggles from laptop -> external -> both.
If it's a PC, it might be a signal incompatibility. Try different resolutions or refresh rates.
Good luck.
Aug 09, 2009 | Insignia 37" LCD Flat-Panel HDTV
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
51F510 Input settings for HDMI
Okey,
Connect the hdmi, into the HDMI 1. that is automatically input one. Connect the 2nd device on Input 2, thats next to input 1 and hdmi, leave the input 1 empty, as the hdmi is connected to that.
3rd device into input 3
4th device into input 4.
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
Insignia NS-LCD47HD-09 47 in. LCD TV Logo
1,196 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
