Question about Princeton Digital VL2018W Monitor
My princeton VL2018W will flash the screen when first powered on but goes blank after. With repeated unpluging, the display used to stay, but no luck.
    Novelist:
  • 159 Answers
The power board probably needs an overhaul. Capacitors are probably the cause. It would have to be opened up to check that.
I repair many monitors through ebay and it is common on a lot of monitors.
If you take it apart and send me a picture to bammbamm@ptd.net, I may be able to see the problem.
Fran
Posted on Nov 18, 2009
3 Suggested Answers
  • 732 Answers
SOURCE: My princeton VL2018W will flash the screen when
floresa57, After lcd panel "flashes" is the lcd panel "black" or is it both "black" and "blank" when you perform the flashlight test that every LCD owner should know how to do and interpret the results? Do you have warranty? If no, then read more responses in my FIXYA profile for clues on what YOU will or what YOU won't do to fix your BLACK SCREEN monitor!!! Floresa57, the basic principles of design and operation of your Princeton VL2018W are same as all other brands of Fluorescent backlit LCD monitors!!! It can be fixed. READ, READ, before you do anything. Understand the reason WHY your monitor is now black and lifeless. Follow all the LINKS to other web sites so you will be informed and less likely to be overcharged on a repair job that should have cost less than $50. Good luck Floresa57. Rate this on FIXYA if it was of some use to you. 12fixlouie
Posted on Jan 05, 2010
budmrtn
  • 11361 Answers
99% will be bad caps in the power supply section. Take the back off and look for caps with bulging top, replace them with good quality caps such as PANASONIC FM or FC series from DIGIKEY.
When i connect the monitor VL2018W TO a power supply without connecting to my pc,i get the message ''NO SIGNAL,SELF DIAGNOSTIC'''.When i connect cable to pc,,there flashing blue light...
* Make sure the cable is connected properly.
* I've you have mutiple interfaces like HDMI & VGA, try switching between these until you get a signal :D
This can be performed by using the build-in options menu.
Jun 14, 2011 | Princeton Digital VL2018W Monitor
Have old computer ,do not have directdvi-d connection on my computer, can I buy adapter to fit old monitor plug?????
Princeton Digital VL2018W has VGA and DVI input ports, why not use the VGA cable from your old PC to the VGA input of the Princeton Digital VL2018W?
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Aug 01, 2010 | Princeton Digital VL2018W Monitor
I reset the resolution on the computer (big mistake) and now I cant see the screen in order to reset it back. The screen turns all blue with two messages and a flash of the windows screen (windows 7). The...
Boot up in safe mode and selct VGA support, then set the video resolution to your Princeton VL2018 native resolution mode (1680x1050 @60 Hz)
See more here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Hopefully you monitor doese not have the same problem (bad caps) just like the other VL2018 as shown in my pictures here (but it will fail for sure later on):
Jun 12, 2010 | Princeton Digital VL2018W Monitor
Had the blank screen problem. Now it won't work above 800x600 res
When I replace caps in this model, I replaced all the caps (4 (1000uF by the heat sink, 1 (470uF) by the inverter transformer) for the 5v and the 12v since you cannot 100% relying on just by looking bulging tops. I am not sure why your has 3-470uf. See my example here: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Jan 23, 2010 | Princeton Digital VL2018W Monitor
Jan 05, 2010 | Princeton Digital VL2018W Monitor
Vl2018W princeton monitor
If the caps you took out are rated at 50v it is best to use that rating, lower value caps can short out and cause additional problems. Also a white screen means 1 of 2 things, either the power supply is still not putting out the right voltage or yo have a small fuse blown on the lcd panel. The most likely cause is the power supply is still not right. If you can take a few pictures of your power supply board and send them to me at tech@ccl-la.com I will see if I can cross reference the board with something and try to help you out.
Buddy
Corporate Computer
www.ccl-la.com
Sep 05, 2009 | Princeton Digital VL2018W Monitor
Blank screen
You said it correct the fluorescent bulbs are going bad, unfourtunately the are part of the screen (panel).
to replace the panel make sure you get the exact part # from the panel inside rear and check prices online and on ebay.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 03, 2009 | Princeton Digital VL2018W Monitor
Monitor does not turn on automatic
change your power cable.
also check your power suply and earthing.
Nov 19, 2008 | Princeton Digital VL2018W Monitor
Princeton Digital VL2018W Monitor Logo
242 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
