Question about HP Pavilion zd8000 Notebook
Stripping down my laptop
I need to replace my keyboard can you tell me how to strip my laptop down the hp zd8000
    Sergeant:
  • 279 Answers
Here's a link to the Maintenance and Service guide:
http://h10032.www1.hp.com/ctg/Manual/c00291986.pdf
It should give you detailed instructions on how to replace the keyboard.
If you have any questions, don't hesitate to ask.
-Dyllan
Posted on Jan 09, 2008
Pavilion zd 8000 note book will not boot. just beeps twice and thats it need list of beep codes for it
Your ram strips need reseating. Pop them out and then refit firmly. If this is not enough, one of them is faulty.
Sep 12, 2010 | HP Pavilion zd8000 Notebook
How to replace keyboard for hp pavilion dv9000
on most laptops, there is either a strip of trim alongside the top of the keyboard which needs to be removed and/or there are clips down on the sides of the keypoard which need to be depressed.
Aug 05, 2010 | HP Pavilion dv9000z Notebook
How do I install a new memory card?
Thats real easy one, open up the Flap covering the RAM underneath the PC, you will see a "Strip" of RAM, carefully pop that out, take care to not touch the Gold Fingers, now have a look at the Description & Numbers on it, now take that strip with you, to the "Memory Shop" :) and select another Strip (Called a DIMM) that is compatible with it. Now simply clip them back into the slots where you removed the first one, they can only go in one way, and can put any DIMM, anywhere, and replace the flap. Turn on the PC, it will automatically "Find" the new Ram & just work.
Feb 24, 2010 | HP Pavilion zd8000 Notebook
How do i replace the keyboard in hp dv6500
First thing is to take the battery out. Then you need to remove the access door that covers the wireless card and Ram memory. In the area where the battery sits, there are three screws, these hold the power strip in place. Remove those screws, now there are two more screws in there up against the battery compartment, these are marked with a keyboard icon, remove these two screws. Now, there is one more screw for the keyboard and that is in the wireless/ram compartment. It is down in a "tube" but marked with the keyboard icon. Once that screw is removed, turn the laptop back over and open the lid. With your fingernails pry up on the right side of the power strip and lift it gently, it will pop up, but be careful because there are a couple of flat cables that connect it to the motherboard. This strip does not have to be removed to remove the keyboard. Just shift it toward the display so that you can grab the keyboard at the top and lift it toward you to clear the power strip. There are no other screws holding it down. Once you lift it up at about a 45 degree angle shift it toward the display and this will allow the keyboard "catches" to release at the bottom of the keyboard. Look under the keyboard and there will be a flat cable attached to the motherboard, this is the last attachment. It is held in place by a tension clip. look at the white or light colored strip of plastic on the end of the cable socket, move this toward the display, it will slide forward releasing the cable. Reverse these processes to put the new keyboard back in. Just remember the keyboard slides under the palmrest at the bottom of the keyboard, watch the keyboard when you remove and you will see what I mean.
Oct 09, 2009 | HP Pavilion DV6500Z Notebook
Webcam not wrking
It sounds like the camera may need to be reseated on the motherboard. Could be a loose connection with the cable. You will need to get the keyboard and power strip off and access the cable from there. The cable runs from the right side of the display across the palmrest to the center lower part of the motherboard and plugs into a small flat socket. To get the power strip off, remove the battery, next...there are several screws you will see, all of those screw need to be removed, there may be 5-6. Now take the access cover off the memory/wireless compartment. There is a screw inside a tube marked with a keyboard symbol, this screw has to come out. Now turn the laptop over and pry the right side of the power strip up gently, just position it forward toward the screen just enough for the keyboard to flip up. Now shift the keyboard toward the screen so that the hold down tabs at the lower part clear the palrest. Now under the keyboard is the flat socket holding the keyboard cable, push the retaining tabs on both sides of the socket toward the screen, this releases the cable. Lift the keyboard free. Youcan leave the power strip where it is, it does not to be removed. Now look to the right side of the display at the right hinge. The flat cable is the camera cable, it is usually bundled next to the two wireless antennae leads. Follow the flat cable down to where it plugs into the motherboard. Pull the plug out and give the socket a blow of air to clean dust and debris. Now plug the cable back in and make sure it seats well. Put everything back together, go to HP and make sure you download the "Cyberlink" Youcan software drivers and the camera should work fine.
Sep 27, 2009 | HP Pavilion dv6000z Notebook
Vertical colored lines and shaded larg strip on hp
i have this problem and i fix it. this is due to vga cold solder on mainboard apply hot solder to vga and memory.
Jul 01, 2009 | HP Pavilion zd8000 Notebook
Need replacement keyboard for gateway ml6732 laptop computer, don't have the old one and have no idea how to put it in. Need directs and need to know if screws come with new keyboard, or if it takes screws...
You may be able to get from Gateway. From a quick search I just did, it looks like Mundo Corp.com, has one. $49 dollars Here is the link,
http://www.mundocorp.com/ml6732.html
Now I don't have a Gateway Service Manual in front of me, for the Gateway ML6732 laptop. I don't believe it's available online. One, has to be an authorized repair shop, to have access to this information.
However, I wish you to know that I am a computer repair tech, and repair laptops all the time.
Keyboard replacement is one of the easier things to do, concerning repairing a laptop.
It is especially easy now for you, as you don't have to remove the old one.
The laptop keyboard will just come by itself, I believe. There are one, or two screws, that hold it in. However, the keyboard has tangs on the outside edges of it. The keyboard 'body' is made of plastic.
These tangs, are just small protrusions, that stick out from the rectangular body of the keyboard itself. The tangs also hold the keyboard in place. Once you sit the keyboard in place, you just push down on the edges, and the tangs snap in. Pop, pop, pop, and the tangs are snapped in.
Before you are ready to install the keyboard, you may have to partially remove a small thin plastic strip. This strip is located above where the keyboard goes, and under the area of the LCD screen.
Viewing it, you should see LED lights in it. There may be speakers in this strip also. The plastic strip goes almost all the way across the front of the laptop.
I know it's starting to sound complicated, but it isn't.
This plastic strip may also have hinge covers, incorporated on the ends of it. They cover the hinges for the LCD screen.
The plastic strip has tangs on it's edges also. To remove it, you take a small flat tip screwdriver,(Like a flat tip jewelers screwdriver), insert it under one of the edges, where it meets the laptop body, and gently pry up.
I say 'Gently', but sometimes it takes a little force. If you can't get the screwdriver down in there, move over. You may be at an area where on of the tangs are.
The strip will come up with a POP! You'll think you broke it! In actuality, you could drive a truck over that plastic strip, and not damage it. (Okay! That's an exaggeration, but you catch my drift)
Watch as you go along. If you have LED lamps in this strip, and/or speaker wires, you don't want to damage the wires.
You are just seeing if you can pop it up, so that you can set it towards the LCD screen. Move it back far enough to get the keyboard in. Should you have to disconnect the wires to move this strip back far enough, you will see real small White connectors. Looks like a small rectangular block. This is a Male/Female connector. Just take your fingernails, and pry these apart.
There may be two wire cables. These cables have different size connectors, so there will be no confusion when reattaching them together.
The laptop keyboard goes in at a 45 degree angle. Bottom towards you, top away from you. You set it down in the laptop body, align the tabs, (tangs), and ease it down. Once you are within about three inches, you connect the one, or two wire cable connectors, from the laptop to the keyboard. Move the cables to a position where they won't be pinched, and go ahead and push the keyboard down into position. Go along the edges of the keyboard, and push down. You are snapping the tangs into position. Snap, snap, snap.
Attach the cables for the plastic strip, if you had to remove them. Watch the cable, (Wire) placement as you did for the keyboard. Snap the plastic strip back into place.
You're done!
This link shows the Gateway MT6704 laptop. It should be very similar to yours. It has large color photos, and instructions, of how to replace a keyboard on this laptop. It should give a basic 'feel' of how to replace yours,
http://www.insidemylaptop.com/remove-keyboard-from-gateway-mt6704-model-ma7/
(If this link doesn't come up as a link you just click on, copy (CTRL + C), and Paste, (CTRL +V), it into your address bar. Then press the Enter key)
If you get time, I would appreciate it if you would rate my solution.
Apr 16, 2009 | Gateway ML6732 Notebook
Replacing a keyboard on an HP Pavilion ZD8000
Here is the site I use when repairing laptops and get stuck. This tells and shows what you need to do. Good luck and have a good day.
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Jan 31, 2009 | HP Pavilion zd8000 Notebook
Display problem
my screeen is black there is sound but no picture
Jun 10, 2008 | HP Pavilion dv1000 Notebook
Replacing zd8000 keyboard
No, its easy to do it yourself. You should not have too much of an issue. I would stick to a factory keyboard to avoid any incompatibility issues.
Aug 28, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
422 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
