Question about Whirlpool GU2400XTP Built-in Dishwasher
Water not heating up in the dishwasher
I have a bosch dishwasher sgs5302gb/07 and the water is not heating up at all can you advise
thank you
  • 25 Answers
This appears to have the controls on the front , this unit the heat relay on the control board would separate from the control board causing the unit to quit heating. the control is located in the panel right behind the push buttons. you will either have to replace the control or you may be able to resolder the relay if the board has not been damaged
Posted on Jan 25, 2008
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
SG13002GB/07 bosch dishwasher: Water isn't getting
1. Water inlet valve is faulty = replace 2. Main motor (circulation pump) faulty = replace
Jun 23, 2017 | Dishwashers
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
There is always condensation on the inside of the door and some water on the floor of the machine after washing. The main thing is the foul odor that is inside the machine after a day of sitting with...
heatman101
Sep 20, 2010 | Bosch Dishwashers
Does my Bosch SHU3032UC have a heat booster?
The dishwasher has a built in instantaneous water heater, so even if the water feeding the d/w is cold the machine will heat it the the temp required for the cycle you have choosen. Reducing the temp will not effect the wash quality at all, in fact having a lower temp or cold water filling the machine will make the drying cycle at the end of the program more effective.
Hope this helps, please leave feedback.
Jul 27, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
Bosch Dishwasher, model SGS6312GB/07. The water does not heat up so the dishwasher does not complete its cycle and remains in wash mode. The water has to be scooped out
press cancel/drain sequence to get water out-check owners manual.
2 possible solutions to your problem discussed here:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
problem may be a burnt out solder connection on circuit board
call bosch to see if it recall issue
Oct 30, 2009 | Dishwashers
How do we replace soap dispenser for Bosch SGS5302GB/07
Unplug the unit. Open the DW door .remove screws.Carefully place it aside. you are going to see soap dispenser unit. remove the wire harness carefully, remove the screws. Replaced it with new one. so simple. assemble back the door panel.
Jul 23, 2008 | Bosch Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
219 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
