Question about Ricoh Aficio 2027 Black and White Copier
Ricoh SC545 code on screen
I am in Fiji A Copier Service Technician mainly in Konica pls Help to do this Ricoh Aficio 2027 which is giving SC545 code on screen, What shall I do and how to reset this code Remem ber I dont have service manual for this.
    President:
  • 1,653 Answers
When the power drops out the thermistor will sometimes give strange errors. This may be caused by toner being caked up on the thermistor itself and in most cases it can be reset.
Wake up the machine in COPY mode and then press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold [#] on the keypad and press [Copy SP] on the touch screen you will be into Ricoh Service Modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
Posted on Dec 09, 2009
Ricoh 2027 please wait is all that come on the screen ?
sounds like the mother board, IBU or power supply. this would be worth calling a technician
Nov 12, 2014 | Ricoh Aficio 2027 Black and White Copier
How do you clean a clogged developer in aficio 2027?
you could do forced developer churn or manually strip and clean, you will need a qualified technician for both options
May 03, 2014 | Ricoh Aficio 2027 Black and White Copier
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
Ricoh Aficio SP 420dn shows SC545 error code after power outage. I'd like to know if there is a way to reset. Thanks!
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
problem solved =]
ta!
Willi
Service Engineer
Apr 20, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Aficio 2027 Black and White Copier Logo
197 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
