Question about Panasonic PT-52LCX66 Projection Television
How do you reset lamp timer with remote given. I read they said hold volume button and halfway switch. Do you hold volume up button or volume down and what is a halfway switch button? Just replaced lamp today but red light is still on.
  • bernard_jewe Nov 16, 2009
    I figured out how to reset lamp tmer by holding volume down on tv and zero on the remote for 5 seconds. After doing this I turned tv off and waited then turned back on and red light on tv is still staying on. What do I have to do now?
  • 2,335 Answers
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Posted on Apr 11, 2010
Reset lamp timer
Simple answer: -vol button on set and split button on remote hold at the same time
I just figured mine out!!!! So many people with so many different solutions. I read the instructions for the TV, those says to read the instructions for the lamp. I read the instructions for the lamp but this model isn't on the instruction list. For other models it says to use the volume down button on the set and the PIP on the remote. No PIP button on the remote. But wait the bottom row of buttons has a multifunction button for split screen! I tried that and it worked. I had a message that said the lamp timer was set to zero. Done! Hope this helps someone out there.
Feb 09, 2014 | Panasonic PT-61LCX65 61" Rear Projection...
I'm pressing the volume - button and the split button but the lamp is not resetting
I think you are trying to reset lamp hours in Panasonic dlp tv, right?
Press and hold volume down button on tv front and press and hold split button on tv remote for at least 6 seconds to reset lamp hours timer.
TV will show you confirmation screen about lamp hours reset.
Jun 29, 2010 | Televison & Video
How to reset lamp timer on panasonic pt-52lcx16
Turn On tv, press and hold Volume Down button on TV Front and Play/Split button on Remote at same time for six seconds to reset lamp timer.
TV screen will show lamp timer reset display upon successful process.
Jun 26, 2010 | Panasonic PT-52LCX65 44" HDTV
TY-LA1001-K I replaced the lamp and didnt restet
I have searched and searched on how to reset the timer. Most solutions say you have to press and hold the volume down button on the tv while also holding down the zero button on the remote, or the pip or split button on the remote until the screen display reads that the timer has been reset to zero or the lamp and power button both flash.
I have tried every combination and cannot seem to reset my lamp timer. If you figure it out, please share it with us!! I'm frustrated and can't get it to work!!
May 07, 2010 | Panasonic PT-52LCX66 Projection Television
How to reset timer on PT-56DLx25 I got the new lamp,but no instructions are in the box on how to reset the timer.
Since all the other solutions were not very specific for some reason. HERE is the right procedure for model # PT-56DLX25.
Press and hold the Volume Down button (On the television set itself, not the remote) and the split button on the remote control simultaneously for atleast 5 seconds and you will get the message "Lamp timer has been reset to 0. Your welcome :)
Dec 26, 2009 | Panasonic PT-56DLX25 56" HDTV
PT61LCX65 lamp timer
Hold the volume down button on the tv until the volume is at min. then continue to depress the volume down button on the TV. While depressing the volume down button the tv hold the pip or split button on your remote for approx 5 sec. You will see a box pop up that says lamp timer reset and gives instruction on how to exit.
Jun 02, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Bulb or Lamp Unit Timer
"paison" was correct and his solution did work for me. Make sure you first select TV on your remote. Now hold down the dvd/vcr button at the bottom of your remote while also holding down the "volume down" button on th front of the TV. Hold until a "Blue Reset Menu" appears on the screen and say the timer has been reset. Noe just follow the on screen instructions.
Dec 28, 2007 | Televison & Video
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Panasonic PT-52LCX66 Projection Television Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
