Yuck. try stat, run , type regedit hit enter. when it opens , go to ..hkey local machine ... software..microsoft...current version ... run. Then highlight anything that DOES NOT have to run... or looks suspect.
Typically, people will get tan error similar to this one after installing a new program to their machine. While this may not be the case for you, I still ask if you have recently installed any kind of program before this started happening. Another option is to go into the msconfig and determine if the program is listed in the Startup section.
Click Start and in the Search box type msconfig. Click on the Startup tab and look through the list to see if something named status.msi is checked to the left. If it is there and is checked, uncheck the box and restart to see if you get the error again. If that is what was causing the error it should no longer appear at startup.
Alternatively, you can go here to this Microsoft fix. Just follow the instructions in the article to download and run the utility >>>>
http://support.microsoft.com/kb/290301
Regards.
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS
STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE
MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR
PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL
MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS
WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY
SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
