Question about GE Profile JTP56 Electric Double Oven
The control panel went dark. Can only read it
The control panel went dark. Can only read it when the kitchen lights are off.
Model: JTP56
maybe 56wow1ww
or 56w0w1ww
    Scholar:
  • 62 Answers
Not sure on the make but it appears that the timer clock display is failing. Replacement cost is typically £80 but without the make i cannot give you a accurate costing. Fitting would be extra.
Regards
Aardvark Repairs
Posted on Nov 16, 2009
  • Brown2 Mar 22, 2011
    The display panel on my GE JTP56 double wall oven went very dim a couple years ago. The oven still works but it's very hard to see the info on the display panel unless the room is dark.
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
Upper oven problem,
The Keypad (membrane) switches seem to be malfunctioning, this is very common on ovens these days especially if the unit has been self cleaned often. If you replace the membrane switch the unit should have all its functions again.
Dec 23, 2007 | GE Profile JTP56 Electric Double Oven
Control panel doesn't work
F7 indicates either a stuck key or the main control has failed. Try depressing each button one at a time checking for a stuck key. If each one retracts I would replace the main control this is more likely the problem. There easy to replace. If you enter your model # at www.appliancehelponline.com you can get diagrams and illustrations of your specific model.
May 27, 2010 | GE Profile JTP56 Electric Double Oven
We were heating up our GE Profile JTP56 double oven to use for the first time after I installed a new Oven Electronic Range Control. It was all looking great...then, it all just went off. The breaker...
Hi--  Since you've gone this far already- let's check this stuff first.  >Power connections at bus block.  >L1 and L2 connections at control.  >Any ground connections.      Start with power off and visually inspect connections.  Bus block is difficult to access for live testing, but can be seen with bright flashlight.  Connections on board route all the power, so make sure all are tight.  Please acknowledge this post if info is helpful- have more if needed.  Thanks- Ed
Mar 25, 2010 | GE Profile JTP56 Electric Double Oven
Removing the control panel on our Whirlpool RBD 275 Oven Door
If you can email me the full model number I can dig up the exploded parts diagram and maybe a link to the service manual for you. I don't know if can can post the image on this site, but I can email it to you.
Regards,
bruce@fixyourboard.com
Sep 22, 2009 | Whirlpool RBD305PD Electric Double Oven
JKP56 and JTP56 Differences
Those are not full model numbers, but basically a JKP56 fits a 27 inch cabinet and a JTP56 fits a 30 inch cabinet, so obviously the key panel / control panel would be different. I looked up a couple ERC range controls, and they are also not compatible. Note: usually you will not need both of those parts. The most common of the two is the front panel. (common F1 error code) If this answers your question a "FixYa" rating would be appreciated. Thanks.
Sep 25, 2008 | GE Profile JTP56 Electric Double Oven
JTP56 Self Cleaning issue
It sounds like you need to replace the door latch assembly. One of the switches on it is not working properly so the control is not getting the correct signal for the door latch position. It could be an oven control problem, but most likely it is the latch.
Post back with the complete model number from the oven if you need more help and I will answer as soon as I can.
Thanks, Mike
May 06, 2008 | GE Profile JTP56 Electric Double Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
162 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
