RCA F19424 there was no picture and the sound worked. I figured I'd change the caps and I went to plug it in and it sounds like the caps are charging but the TV never turns on.
  • 1 more comment
  • spoolin_awd Nov 16, 2009
    the chasis number is CTC203U5
    Thanks I will look into that when I can stop being a chicken and discharge the darn thing. The TV wasn't even turning on after the caps. You could hear it charge up but it never really finishes charging. I didn't use any caps that were not good replacements so I don't know why its not even turing on now.
  • spoolin_awd Nov 18, 2009
    It does not have a vcr.
  • 1,210 Answers
The caps were not the problem to begin with. Can you still get audio? If so....Find the Horizontal output transistor....next to that is a 100 ohm 1/2 watt resistor and next to that is a small coil.....Unsolder the coil and clean the two ends of the coil and the area on the board,,,and under the board where the coil was. These solder connections on the board are not creating a good ground as the glue, is acting as an insulator!
Posted on Nov 16, 2009
  • 1 more comment
  • matt martin
    matt martin Nov 16, 2009
    You may have inserted a cap using wrong polarity [could swell up or pop] or wrong microfarad. You will have to open and see. It is always good to document each step you take when replacing parts. The other thing I want to ask, does this tv have a vcr? The heads on the vcr can be so dirty, that you will have audio and no video. On the otherhand you have video with cable or satelite if this was the case.
  • matt martin
  • matt martin
    matt martin Nov 18, 2009
    Then proceed and see if you can find the cap you installed. The ones to worry about are the 160v 100mf to 200v 100mf and the 200v to 250v 470mf caps! They will slowly drain in a week or two.
2000 rca home theater system. The sound stopped working. Can I use/get an external speaker/sound system and plug that into the audio output? The picture is perfect, hate to get rid of it.
I would certainly try it!
It may or may not work depending upon what went bad in the sound part of the TV. Most likely it will work because the majority of the sound failures are in the power circuitry.
Just be very careful in unboxing the sound system, you may end up having to take it back if it doesn't work.
Any sound system that includes as inputs "Auxiliary Audio" should work. (2 RCA jacks) Your TV may have a surround sound capability, but you'll have to check your manual.
Aug 03, 2016 | RCA Audio Players & Recorders
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
RCA l42wd22yx5 green screen when on HDMI... Still get sound
We had the same problem. What we did was unplug our DVR box from Comcast to reset it and plugged it back in and the picture came back.
Dec 05, 2009 | Televison & Video
TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Disconnected RCA plugs from 52'' RCA and now no sound even...
ont back of the set there are a set of jacks you can hook ext speakers to make sure that switch is turned to int speakers
Nov 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Oct 09, 2008 | RCA Televison & Video
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
RCA F32650
I let it go and she corrected by herself. What do you think?
Aug 14, 2006 | RCA F32650 32" TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
