Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE refrigerator, ice melts in ice bin
GE profile, PSW23PSTASS, S/N VL416529, mother board P/N WR55X10156.
The ice maker bin fills with ice, but later melts in the bin, drips down into the freezer and forms large icicles. Ice cream seems to be melting and re-freezing. Also, there is frost on the outside of some other items. The built-in thermometer continues to read 0 to 2 degrees as always. I turned off the ice maker 2 weeks ago, the icicles are gone but other symptoms remain.
Solutions to similar posts included water solinoid valve (probably not as ice maker off and problem persists), bad mother board, defroster heater stuck in on position. If auto defrost please explain specific parts to be replaced.
  • gdoliver May 11, 2010
    I Have the same problem and tried AASC's recommendation. Worked great for one week, and problem is back. Any other ideas to try? gdoliver@gmail.com
  • GE Master
  • 1,606 Answers
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Nov 16, 2009
Mines doin the same thing this is a chronic problem with these units. I think it has something to do with the fan on top of the coils that brings the cold air up to the ice maker section. Seems to run a little slow or not often enuogh.Could be the fan motor, but more likely the board which powers the fan and is 230$$.Pisses me off Ken
Posted on Jan 03, 2010
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
I have a problem with a GE Profile PSS26PSSASS. The ice maker barely makes any ice. The ice that is made, is melting, dripping, creating icicles in the freezer, and then re-freezing in the ice bin as a...
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 17, 2011 | GE PSSS3RGZSS Side by Side Refrigerator
The ice maker stops making ice, and the freezer goes into a melt-down mode. This goes on for days. Sometimes, I buy a bag of ice, pour it into the ice maker bin...and PRESTO, the ice maker begins to...
you may have a p c board failure . it has not completely it will . the board gets stuck in defrost and you have a melt down . ( main board d wr49x10152 ) / if not the board ck when it hapens the evap fan in back of freezer .. .. also ck for frost in back of freezer .. mm
Dec 17, 2009 | GE Profile PSF26PGSBB 36" 25.5 Cu. Ft....
The ice melts from the ice maker forming icicles down below.
Just had this same issue repaired yesterday, the defrost element was out allowing the freezer to freeze up stopping the fan which moves the air and in turn causing the upper part of the frezzer to become warm and melt the ice. This is a common problem for the GE profile and I recommend finding a service company cheaper than GE and quit letting GE make more money off their CRAPPY appliances.
Oct 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
1,648 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
