Ink system failure
I have an HP Photosmart 8250 and I recently had to change the yellow ink cartridge. Well, ever since then, I get the message "Ink System Failure, refer to printer documentation". ERROR 0xc18a0001. Then it tells me to turn the printer off and on .. but it still doesn't work.
i have a problem with the hp photosmart 8230! im also getting the error message saying "ink system failure" i tried the tricks that worked for the other hp models but no luck, any ideas???
  • Omad Jan 10, 2008
    yeah i tried the things on the HP solutions page but no joy
  • Omad Jan 11, 2008
    SORRY STILL NO GOOD
    Sergeant:
    Champion:
  • 347 Answers
Hi Omad, go to this link
http://www.fixya.com/support/t222625-ink_system_failure
It was a similar problem they had on fixya. Well pretty much the same problem. see if that can help you, if not, let me know
Posted on Jan 10, 2008
  • Santiago Vallejo
    Santiago Vallejo Jan 10, 2008
    you can also try to call HP and ask for your warranty if you still have it
  • Santiago Vallejo
    Another thing,
    Soluvisitor might be right, It can be a problem that shows on the printer, when it detect damaged, or other Ink cartridges that the ones you should use with that printer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Here is the solution, follow the link and it will tell you how to clear the message.
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=nl&cc=be&dlc=nl&docname=c00719450
  • 1,113 Answers
First can you tell me if you are using HP original inks or aftermarket ones? If you are using after market ones then the cartridges are the problem.
If on the other hand you are using genuine HP inks then you need to follow HP's recomendations and install the update patch..
  • 2 more comments
  • Soulvisitor
    Soulvisitor Jan 10, 2008
    Are you using HP original inks???
  • Soulvisitor
    I fix these under warranty, The first thing I do is replace any inferior or old inks with correct acticle, this solves 70% of problem
    Then I install update patch to firmware.
    The only other thing I do is remove all carts, power up machine, reinsert cartridges.
    With the 2 % of machines that fail, It is due to contaminated ink blocking the ink system, HP dont stock parts for this model, they replace whole unit.
  • Soulvisitor
    Soulvisitor Jan 11, 2008
    Omad.
    Please let me know if what inks you have in this machine, If you have sucessfully installed the patch and you are using aftermarket inks then you will need to replace them with new HP ones.
    I can't help you any further without more infomation.
    Cheers S.
  • Soulvisitor
    I take it that you are in fact using non gen, hence no responce to question and that is your problem. REPLACE INK with Genuine products designed for your machine.
  • 589 Answers
Ink system failure have tried everything such as resetting and nothing works
Have you installed a new cartridge or tried the old one that worked to see if the new cartridge you have was bad out of the box?
Jan 07, 2010 | HP - HP Photosmart 8250 printer
HP 8250 Photosmart printer that displays "system ink failure"
Try changing the ink cartridges.
If you installed the "HP Support Toolkit" software from the CD-ROM that came with the printer, use this Toolkit to "run a cleaning cycle".
It can print a "test" page, to show you which colours _do_ work, and which do _not_ work.
If all else fails, then find a qualified printer technician.
Dec 31, 2009 | HP - HP Photosmart 8250 printer
Ink system failure. How do I reset a hp 8250 printer?
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the printer, wait for the printer to prompt that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime the ink cartridges. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Nov 15, 2009 | HP - HP Photosmart 8250 printer
Ink failure system error
1. Turn the printer off for few minutes then turn it back on
2. Clean ink cartridge
3. Update drivers
4. If nothing works, repace the battery
Sep 07, 2009 | HP Photosmart 8250 InkJet Printer
Can't print on 8250 photosmart printer
See http://www.hp.com/pageyield/articles/us/en/InkExpiration.html on how to override error.
Apr 19, 2009 | HP Photosmart 8250 InkJet Printer
Ink system failure
it could be a viros or a printer jam
Aug 16, 2008 | HP - HP Photosmart 8250 printer
Ink system failure
well nothing to say but!!! go get a new one!!!!
Jul 12, 2008 | HP Photosmart 3210 Printer
Ink system failure
Hi ok try this I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 18, 2008 | HP Photosmart 8250 InkJet Printer
Ink system failure
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Jun 06, 2008 | HP - HP Photosmart 8250 printer
235 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
