Question about Ovens
I have a shacklock 501 coal range stove that I would like to have repairs and restored. I live in Porirua, close to Wellington
Do you have a thermonstate for a preway wall over - model 501-1
  • Range/Stove/Oven Thermostat Parts In Stock from ... www.repairclinic.com/.../a13c24/Range-Stove-Oven-Thermostat-Parts Shop for your Range/Stove/Oven Thermostat from our ... What is a model ... Repair Help. SEARCH. Range/Stove/Oven. Thermostat. Clear All. Range/Stove/Oven Thermostat ...
  • Preway Wall Oven Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Preway Parts Shop the best selection of Preway wall ovens repair parts and accessories at Sears PartsDirect. ... Preway Wall Oven Parts ... Model retention may be affected by your ...
  • Preway Oven - Network54 www.network54.com/Forum/124162/message/1109513545/Preway+Oven Preway Oven February 27 2005 at ... I like you was searching for information on parts for a Preway wall oven we have in our ... I have the manual on the oven. The ...
  • Mar 24, 2016 | Ovens
    2 hobs on my electric cooker are not working
    Fixing Electric Stove Burners that Don't Heat Up Properly ...
    ? 2:34
    www.youtube.com/watch?v=GfqaPcha__o
    Jul 2, 2012 - Uploaded by SamuraiRepairman
    Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
    Electric Range Stove Repair: How To Repair Burner ...
    ? 6:52
    www.youtube.com/watch?v=ndQU7RtqfRw
    Jan 31, 2012 - Uploaded by applianceassistant
    How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
    Oct 26, 2015 | Ovens
    SHACKLOCK TM620D double oven - hinge spring broken. Where can I find a replacement in NZ, preerably Wellington?
    Try these: http://www.egleys.co.nz/index.asp?pageID=2145828187 http://www.dougsmithspares.com.au/Appliance%20parts%20New%20Zealand%20NZ%20delivery.htm
    Oct 28, 2013 | Ovens
    My kenmore elite stove model#790 the oven and broiler do not heat up but the fan runs
    Since none of the burners or elements will heat, I recommend that you shut off the house circuit breakers for the range. Your symptoms point to a voltage supply problem. The range should have a double breaker (the two circuit breakers are probably connected together with a metal clip). The range clock control will light up if only one leg (L1) of that power supply is provided to the range. If the second leg of power (L2) is missing, then none of the burners or oven elements will heat. You could have a problem with the circuit breakers or the wiring on the terminal block at the back of the range. With the breakers shut off , I recommend that you pull the range out and check the wiring on that terminal block. Based on your description, you may find a loose connection or burnt wiring in that area. The image below shows wiring information for the terminal block and the junction box for the range. This information should help you check that issue. If you can find a wiring failure and restore a proper voltage supply to the range, then the stove top burners and oven elements should heat properly.If you find no problems with the wiring, then you could have a bad circuit breaker or a problem with the house voltage supply for the range. An electrician will normally need to diagnose and repair that type of failure. I hope that this information helps. If you need more assistance, reply with additional details. If you need parts, you can order them from the Sears PartsDirect website.If you get to a point where you need to have a service technician repair this failure, you can schedule service through this link: Sears Home Services .
    Nov 27, 2012 | Ovens
    My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
    My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
    Oct 31, 2010 | Ovens
    After self cleaning cycle, oven door will not open. the lever won't move.
    in the rear of the stove there might be a wax motor that has melted not allowing the stove to be unlocked. or a stuck switch.
    all too common with self clean ranges.
    unplug stove, remove rear panel and begon looking for any type of heat damage, or any switches that may have been stuck closed.
    i see this at least once per week
    Oct 09, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    My kenmore oven is beeping and will not stop. the display shows F-1.
    Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
    F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
    KENMORE - 911 Series (General Electric/Roper)
    F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
    KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
    F1-E0 EPROM Error - Electronic Range Control (ERC).
    F1-E1 EPROM Error - Electronic Range Control (ERC).
    F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
    F1-E3 Fuel Type Fail
    Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
    “9” for gas-If code changes again-replace Electronic Range Control (ERC).
    KENMORE - 790 Series Electronic Oven Control (Frigidaire)
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
    Runaway Temp = Replace Electronic Oven Control (EOC).
    Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
    Dec 16, 2008 | Ovens
    My kenmore electronic stove is having a beep with code F1 on the
    Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Gas stove with electric starter
    regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
    Oct 23, 2008 | Ovens
    Ovens Logo
    554 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
