My Hitachi 50UX10B TV has sound but no picture.
  • 19,396 Answers
Hi.
If you get audio, no picture whatsoever, not even TV menu, screen is completely dark, sound is OK, then it is usually the ballast board.
The ballast board is an high voltage board powering the lamp or the CRTs.
If you get audio, and TV menus or PIP, but you have no raster, and the menus on screen are displayed correctly, then the fault is concerning either the video input/video processing on main digital board, or the optical group.
Lamp and ballast are working since you can see TV menus and closed captions.
Test the TV using different inputs and input cable (you may have gone through this already). Try at least two different inputs (eg AV cable, SCART, component , HDMI...)
Ensure you use Source/Input button to browse channels.
That can at least tell you if the problem is the video input, or the video processing.
Either than that you will need a technician testing the TV at component level to find the fault.
If you want to contact an authorized technician, or if you want to get a quote on repair, you can call the number listed on the owners manual.
Regards.
Posted on Dec 09, 2009
Sound but no picture,black screen hitachi#50GX30B Was watching Tv then I think I heard a little pop and no picture just sound
hi voltage transformer went need a professional to fix unless you can get parts and solder it in
Mar 27, 2014 | Hitachi 57F710 TV
Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
Mar 28, 2010 | Hitachi Televison & Video
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Works on occasion.
I believe this set has two relays in the power supply. One for standby power and one for full power. I have seen cases where the full power relay drops out or not energise causing the same symptom you describe. Lightly tapping on the relay sometimes identifies the culprit.
Hope this helps
Skyassoc
Jun 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
No sound on 50 inch hitachi tv
Have you checked other inputs with a known good program source? Mute button on remote?
Apr 27, 2009 | Hitachi Televison & Video
HITACHI 50ux10b rear projection TVfrom about 1993
Hello repko,
This looks like a problem related to your High Voltage Protection circuit. This circuit shuts the TV down when it senses a high current condition (a short in a vital circuit). It may not involve extensive repairs, but it will involve some repair work. I can give you a better diagnosis if you do a few things for me.
1) unplug the TV and take the lower rear panel off
2) look at the back of the panel or in the TV for a chart showing you the diagnostic LEDs
3) Look at see if LED D912 is red or not (this may differ in your model, if so write down the numbers of all the diagnostic LEDs and there condition on or off red or green.
4)post these in a reply to this topic.
Once this is done I'll be able to give you some idea of how extensive this may be.
Thank you,
I hope this helps,
Shuttle83
Nov 20, 2008 | Televison & Video
Hitachi rear projection tv 50ux10b Picture and sound would periodically go off and then come in the past few days ---Now , the Red light comes on indicating that there is power , but no more sound or...
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Jun 02, 2017 | Hitachi 50UX26B/27K 50" Rear Projection...
HITACHI 50UX10B AP23 CHASSIS NO POWER
please check all the lights that are in the chassis hitachi puts led in the chassis so that if one of the lights are not working then u know that circuit is bad. now there is 2 things that hit has wroung in the units and that is a 2kv hv cap of the horiz output transistor that burns up and kill the power supply look for a small black or brown fuse it will not have glass on it it is rt behind the reg ic in the center of the chassis it allwas opens up because of the hv cap doonot run the tv without out that cap it will overload the horiz drive and will burn upo the horiz output but u have a very good ctv ther if u fix it will last u a long time and it is a very easy tv to trouble shoot.
Oct 12, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 50UX10B rear projection TV
Good Day, eledttech;
Symptom: NO SYNC ON MAIN PICTURE PIP OK
Cause: IX04.
Good Luck, big IRISH.
Aug 18, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 57G500a no picture but has sound
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture
Replace IC (TDA8385J)
Check the LOT cable for short circuit
Nov 24, 2007 | Hitachi 57G500 57" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
