Question about Brother Sewing Machines
I just bought a Brother Innovis 1200 and it's jammed. I was sewing for a litle while and everything was great. Then it jammed and said something about the safety device was activated. I rerthreaed the machine,, checked the needle, bobbin, tension, etc. Everything the book said to do. If I try and sew the needle won't go down and the bobbin area just shakes and groans. I didn't see any thread stuck down there. The handwheel is verry tight and isn't much help moving the needle. What am I doing wrong?
    Brigadier General:
  • 3,513 Answers
It could be a problem with the top tension, or could be a problem with a damaged bobbin case. If the first thread jam pulled the bobbin case out of place any, there is a chance the hook may have left a gouge in the bottom of the plastic bobbin case. It has to be very smooth, and any rough spot will cause problems.
remove the bobbin case, open the shuttle cover, remove the hook, then see if it will turn. Could be as simple as a thread lock in the shuttle area.
A drop of oil where metal moves against metal might help as well.
It really Sounds like a thread lock/jam.Usually a very tiny piece of thread will get caught in the hook area, between the bobbin case base, and the hook.
Sometimes turning the machine in reverse will start to help free it up, but it takes a very small amount of force to start the movement when the machine is froozen.
So ,If you are unable to turn the machine by hand, it could be as simple as a thread lock/jam in the bobbin case. Or it could be due to being gummed up, and needing a good cleaning, and applying new oil.
chek this site for further help..
http://www.tandtrepair.com/600TandSstuff.html
Thanks for contacting Fixya.com
Posted on Nov 16, 2009
Cannot change stop start button on innovis 1200 sewing machine
The start/stop button won't work if your foot control is plugged in, or if your presser foot is up.
Sep 07, 2016 | Brother Sewing Machines
Brother innovis 4000D. Start stop buttons stuck in red, Machine beeping and screen light but blqnk
If your machine was serviced before purchase and now doesn't work, return it to be re-serviced and made functional.
Jul 05, 2016 | Brother InnovIs 4000D Computerized Sewing...
Brother innovis le cant get scanned picture off previous design
Hello Tarakeira
Here is an electronic manual at
http://www.manualagent.com/brother/innov-is-750e/users-manual/page-10
It is for for the 750E, but will be useful for your instance.
Happy Sewing
Apr 30, 2015 | Brother Sewing Machines
What is code TH-PM ? Brother Innovis 4000D... and how do I fix??
This is a pulse motor failure. You cannot fix this without testing mainboard and Pulse motor. Take it to a mechanic. Sorry for the bad news
Nov 13, 2014 | Brother InnovIs 4000D Computerized Sewing...
Brother innovis 1200
remove the embroidery unit, change the needle and check again in the bobbin case for tangled thread. Same problem here and this is the way I've fixed it
Aug 04, 2014 | Brother Sewing Machines
Hello, I have a Brother NX200-Innovis computerized sewing machine. It was sewing like a dream when all of a sudden it slowed down and beeped and flashed "E6" . The balance wheel has completely...
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Aug 10, 2011 | Brother NX-400
Thread stuck in a Brother innovis 1200 sewing machine.
that is probably a glitch in the build, so a service repair would be necessary
Nov 29, 2009 | Brother Sewing Machines
Sewing Machines Logo
96 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
