Heard pop while baking - control screen quit F1 error message
Oven was on bake @350 F. and we heard a pop. F1 showed on the control screen and the controls wouldn't work. Manual said that error message meant that the electronic control had detected a fault and to shut off and unplug for 30 seconds and then plug back in - and to call for service if the problem didn't go away. The controls still didn't work and it continued to beep. Hitting the clear/off button doesn't do anything - hitting clear makes the control shut off for about 15 seconds, then the bake light comes back on and it continues to beep
    Scholar:
  • 108 Answers
While it may be a cost saver, it sounds like you have read whats out on the net, for safety I would suggest hiring a pro, something like a oven you might "get it to work again" but Was it done correctly?. did you verify other componets wern't failing?. and Its fully safe and ready to go?. you dont wan't a random short or malfunction to happen when you are out and a complete malfunction happens possibly costing you a home instead of a service call..
I more than support doing it our selves, but something like a oven etc just play safe and hire a pro.
Posted on Nov 16, 2009
    President:
  • 1,865 Answers
You will have to replace the control board. you can purchase one online from one of the follow websites. You will need your model number
http://www.searspartsdirect.com/partsdirect/index.action
http://www.apwagner.com/
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
When I pushed the bake oven button on, I heard a loud pop! I thought a light bulb above my range (microwave oven bulb) blew out. Then F1 came on the range screen. We turned off the power to the range...
The F1 error code means one of two thing;either the touchpad is bad or a relay on the conrtol has shorted out. Well the loud pop and the F1,their is not doubt that a relay on the control has indeed shorted out. The fix for that is to replace teh control
PLEASE NOTE A SHORTED RELAY WILL MAKE THE HEAT ELEMENT TO STAY ON AT ALL TIMES AND THE BREAKER MUST BE LEFT TURNED OFF AT ALL TIMES UNTIL THE CONTROL HAS BEEN REPLACED OR IF LEFT ON THEIR WILL BE A VERY VERY GOOD CHANCE OF THE OVEN/HOUSE CATCHING FIRE
Aug 07, 2011 | Frigidaire Kitchen Ranges
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
What does code F1 mean?
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE_ Some models incorporate the touch/Key pad into the ERC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the ERC (Clock).
Jan 04, 2010 | Kenmore 41389 Electric Double Oven
Whirlpool oven timed bake feature dosn't work.
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 25, 2009 | Whirlpool RBS275PD Electric Single Oven
F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
Aug 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Our electric tappan dual radiant baking and roasting oven is beeping and giving an f1 message
Hi gracie7773,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2009 | Tappan TGF320 Gas Kitchen Range
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
Kenmore range control panel not working
sounds like the control board blew on you replace it.
Dec 16, 2008 | Kitchen Ranges
56 people viewed this question
k24674
jasbo
jasbo
