Question about Microsoft Xbox 360 Controller
1st and 4th Quadrants light up/Controller unresponsive.
My controllers quadrants only light up in the 1st and 4th light but does not function on computer or Xbox360. Is the circuit board fried?
    Problem Solver:
  • 5 Answers
Possible but doesn't sound like it. Sounds more like a problem with the wire not supplying enough power to the pad to provide a stable connection. If you can get hold of one off of a friend/relative/hobo then try using the usb connector with the lead, if it works then its the connector thats your problem and would probably be easier/cheaper to buy another pad. If it works just try and buy another connector or hope that your friend/relative/hobo is generous.
Posted on Nov 17, 2009
The formula for the volume of a cylinder with a height of 5 units is mc026-1.jpgwhere r is the radius of the cylinder. In which quadrant(s) is the graph of this function V(r)?
All in the 1st as you can't have a negative radius meaningfully. If you do, the graph is in the 1st and 4th quadrants
Pi * r^2 * h is always a positive answer anyway.
Mar 04, 2014 | SoftMath Algebrator - Algebra Homework...
My Xbox 360 controller appears to be having some issues: i turned the xbox on, and it is immediay prompting me to download an update from Xbox Live, however, I cannot get my controller connected to get rid...
There is a connect button on the controller as well. See this site or follow the instructions below. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/connecting-game-controllers.aspx
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  3. Press and release the connect button on the console.
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected.
Jun 30, 2011 | Microsoft Xbox 360 Controller
Red rings on the xbox 360 wont connect to live wont let me recover gamertag
The red rings are a fatal Xbox 360 error. There is no way to solve this problem except by having a qualified professional perform a reflow to the problem Chip. This can usually be determined based on the number of quadrants lit.
  • 1 Red Quadrant is usually System Error. A "E##" error code will be displayed on the screen. Most common is E74.
  • 2 Red Quadrants indicates the console is overheating.
  • 3 Red Quadrants indicates hardware failure. A secondary error code can be acquired by pressing and holding the sync button then while continuing to hold the sync button repeatedly pressing the eject button and noting the number of red quadrants that becomes lit.
  • 4 Red Quadrants indicates that either no A/V (Audio / Video ) Connection is available.
Good Luck! Let me know if you have any further questions. If you tell me which number of quadrants or the error code I can point you in the right direction.
Jun 04, 2010 | Microsoft Xbox 360 Console
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
What is RROD? I'm not knowledgeable about the X box but am comsiedring buying a used one for my grandson. Can you help?
RROD stand's for "Red Ring of Death." its a problem of epidemic proportions the xbox 360 has been facing since it first hit the market almost 4 years ago. The front of the Xbox has a reticule made up of 4 light-up quadrants. Typically these lights glow green when the console is activated & usually only indicate how many controllers are connected to the console. When these quadrants ever glow red, that means there's a problem with the hardware. the "RROD" consists of 3 of these quadrants being lit up. if this ever happens, the console will have a complete system failure & will almost definitely never work properly again unless repaired. if someone is selling you a console that he/she describes with "RROD" in it's description that means the console is currently suffering from that particular problem. Now, if the console is still under warranty (which has been extended to 3 years now) & hasn't been tampered with or previously refurbished, it can be sent in to Microsoft for repairs completely free of charge. I'm assuming your drawn to these "RROD" described consoles because they are significantly cheaper than the new or used ones you've seen am i right? it is most likely that these consoles no longer have their warranty & are being sold because either their owners have no means, cash or desire to fix them themselves or they're selling them for use as parts to more tech-savvy buyers. whatever the case may be, be careful in your purchase.
Oct 29, 2009 | Microsoft Xbox 360 Console
Wii fit balance board 3 quadrants are green and 1 is red
This means that one of the 4 sensors is broken. You will need to contact Nintendo via their website to get it repaired.
Good luck, and sorry about that!
Feb 11, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Lips game microphones won't connect
I have just tried again and again! Just do what it says in the manual! The quadrants don't light up! go through the install process and give them a try and they should work. That's all I did and they worked fine. Good Luck
Dec 26, 2008 | Microsoft Xbox 360 Console
Mi xbox360 controler lite suddenly started to glow by circling
Does it glow in all four quadrants and doesn't go to the player 1 quadrant? If it does, I think I just barely got past that problem! What you need to do is: Turn your controller on (make sure the 360 is on first) press the connect button on the console, then the most important part: HOLD THE CONNECT BUTTON ON THE CONTROLLER! This was a real biggy for me, i just tapped the button instead! hope i helped!
Dec 24, 2008 | Microsoft Xbox 360 Controller
Xbox 360 guitar hero 3 controller [wired]
try restarting your xbox, make sure your controller is properly connected, and try replacing the battery.
Aug 01, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
519 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
