Question about Dryers
I have a Whirlpool electric dryer model# LER5644AWO and I just replaced the thermostat/fuse (kit 279769)because I had the heating element checked in town and was told it was the thermostat/fuse.Dryer worked for two loads and now I'm back to no heat. What's wrong?
    Scholar:
  • 86 Answers
Check your breaker - a dryer will spin at 120 volts but needs the full 240 volts to dry. If that's not it, and it checks out to be your heating element or your thermostat fuse again, you may have some wiring problems in your house (possible power surges). Check your vent from the dryer to the outside of the house - if this is clogged, it may be shorting out your fuses. Hope this helps,..Good Luck...
Posted on Nov 17, 2009
Testimonial: "Didn't realize that 17 yrs of lint would accumilate in the dryer shaft all the way down to the blowerfan. I'm all good to go now. Thanks!"
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
Whirlpool GEW9200L Electric Dryer won't heat up
The heating element can fail open. Curious that Whirlpool did not mention that possibility.
Jan 25, 2018 | Whirlpool GEW9200L Electric Dryer
Model # 110.86820100 runs without heat, doesn't dry clothes
This is basically a Whirlpool dryer and they are notorius for having the thermal break fail. Disconnect dryer, remove back panel. The heating element is on the right side in a metal duct. On the left side of that duct is a small round disk with 2 red wires going to it. That is the non-resettable safety. Remove both wires and use an ohmeter to check for continuity. If there is no continuity, the thermal cut off and the thermostat at the bottom of the element MUST be replaced as a kit.
PN 279769
If thermal is good, check the heating element for continuity. Remove red wire from element and check across ELEMENT terminals. No continuity? Replace element pn 4391960
Both problems are generally caused by lack of air flow. Make sure that dryer has good air flow to outside after repair or you will get to do this again!Your part: 695563 Substitution: 279769 -->
Mar 03, 2010 | Kenmore Dryers
Whirlpool dryer MOD: GEW9868KQ2 wont heat. does turn on ok. have the element out see no breaks. Fuse maybe? where is it located?
You have a bad thermal cut-off . This piece , is a small thermostat looking piece , located ( from the front ) farthest back , on the element housing ( containing the element ) , with 2 wires going to it . Pt # 279769 . This part also comes with the hi-limit thermostat , which should also be replaced .
Nov 22, 2009 | Whirlpool Dryers
I am replacing the thermostat on my Roper dryer. Model number of dryer is RES7745RQ0. I went to a local parts supplier and I received the ''Thermal Cutoff kit'' with the part number 279769. The spade...
it may be 279816. it can also depend on what thermal fuse you are trying to replace.part # 3977393 includes both the fuses that go on the
heating element can
Sep 26, 2009 | Dryers
MODEL NUMBER:110.64892401 Electric dryer....No heat. Light is on and operating,just no heat:(
very common, you either have a bad heating element or thermal cut out the heating element part number is 3387747 thermal kit # is 279769 whirlpoolpartssurplus.com mark
Jun 24, 2009 | Kenmore 63942 Dryer
My dryer not heat
I need to know the model n serial# to assist you better
Thank you
Apr 27, 2009 | Kenmore 63942 Dryer
My Kenmore 80 series electric dryer won't heat. I
The bottom limit is engineered to open at 250F and the small top one is supposed to open at 300F. The bottom did not have time to click in and so it is considered weak. the kit comes with both thermostats in it Part number 279769
Mar 07, 2009 | Kenmore Dryers
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Nov 07, 2008 | Kenmore 63942 Dryer
My whirlpool LER2614EW2 DRYER WOULD NOT HEAT
do you have a voltage meter?? if so with the back off and the unit running on high heat check the voltage at the heating element if 0 volts unplug unit and lookup the left side of the element casing and you will see a thermal fuse check to see if it is good it should be closed across the terminals it is the size of a nickel or so. you can jumper it out to see if the element is good If it is bad the part # you need is a 279769 which includes a new hi limit stat NOTE*** this is a one time thermal fuse the main cause for this to blow is a clogged up vent system so check your vent and clean if needed
Nov 17, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
136 people viewed this question
Top Dryers Experts
