Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Change Motherboard For Dell Dimension 5150
Hi Everyone ,
I would like to change the motherboard of a dimension 5150 system,What are the options i have ?how can i upgrade just the motherboard without any problems.Or does it have to be the same board for this system.
Please advice.
Thanks a lot.
  • 1 more comment
  • alpha2008 Jan 09, 2008
    Thanks Morgan ,That shouldnt be a problem, How to find a nearest matching motherboard cause i have never faced a problem like this b4.Are there any constraints when looking for a new motherboard like the size etc to look for??How to find a matching board?
    Thanks.
    Yes ,my question is what to look for when buying a altogether new motherboard for the system.What key things to look for ?
    Thanks.
  • Cary Hight
    Cary Hight Jun 23, 2008
    I just need to find a board that will replace the connolly E187242 F2 mobo or where to get this board.
Want to up grade my processor in dell dimension 5150,but don't know if it is capable of running a higher version processor.......
Posted on Dec 15, 2010
With the way the case is made you have to go with a dell motherboard for your power cable ...ect. to hook up right. Unless you want to buy new wire and run them yourself. Also you have to make sure you get a BTX board.
Posted on Sep 19, 2008
    President:
  • 317 Answers
If you replace with the same motherboard that's in already, that would be easiest for you.
But if you use a different one, you'll have to re-activate Windows, and download and install new device drivers.
Posted on Jan 09, 2008
  • Peter Burns Jan 09, 2008
    I usually get them on ebay.
    click here
    The main thing to look for is a motherboard that is the same socket as yours. That way your current processor will fit into the new motherboard. To check this for sure, you'll have to remove your processor and look to see what it says, you can see this under the processor. It looks like yours is either a socket 775 or 939.
USB ports not working on dell dimension 5150
Hi, ship it to these guys at http://www.generalsystems consulting.com
They will fix it and ship it back to you. It should cost less than $100 which includes return shipping back to you by fedex or ups.
Mar 10, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hi is the Power supply on a 2006 Dimension 5150
What makes you think you have a dead power supply? I would look at the connectors and see if there are 20 or 24 going into the Motherboard main connector. Then look for a 4 pin connector plugging in near the CPU. If it looks like the mounting holes line up, you have a winner. Most are interchangeable anyhow. Try to get some SATA connections on your new one.
Dec 19, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Amber Flashing Power button on bootup
i would change the battery first of all. this is the reason for losing date and time
Jul 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 - Options for upgrade
Usually motherboards corresponds to the Dell Number. You can change your motherboard alone from a local technician. However, that's strongly not recommended.
Jan 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 won't start
See solution in http://www.fixya.com/support/t1372311-start_up_fault
Dec 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension E510
A few potential problems:
1. Your CPU fan isn't working, causing your CPU to overheat and then turn off the system
2. Your power supply is faulty
3. A capacitor has blown on your motherboard
Give us more details on your problem so we can figure out what's going on
Jul 27, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
7,107 people viewed this question
Alun Cox
